Where is the best place to mount some tow hooks?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, May 8, 2000.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    In the front or rear? And where at in the front? where are yours mounted? if you guys have any pics that would help to! (sorry for all the ?'s)
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Most guys put them on the bottom of the frame rails in the front. As for the rear, just mount them on the frame somewhere. Or if you have a towing hitch, you can buy a hook that slides in the receiver. Its tons better than putting a yank strap around a hitch ball and having it break off and hit someone in the head and kill 'em.
    '73 K5
    Chevy good...Ford bad
  3. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    I'd have to say at least one on each end.I can't make any suggestions for the rear though,I still can't find a place to mount any back there.I'm in the process of making a bumper with strapping spots built in.
    <font color=red>Wanna'keep wheelin? Get involved!
    Check the "Land Use" section of this board.</font color=red>
  4. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    On the front I have one mounted on each frame rail. On the rear I have a receiver hitch that had some beefy areas for safety chains. I have a clevis in each unless it will be puling really hard, then I use some chain around the main cross piece of the hitch.
    Mud is just thick water, or is it that water is just thin mud?
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    For a receiver hitch, I think the best thing to use is either a receiver shackle bracket or a tow hook bracket. It's a piece of 2x2 steel with either a clevis/shackle or a regular tow hook mounted to it. These stress the receiver the way it was built to be stressed. Just my opinion, of course...
    For the front, you can put them on the bottom of the framerails, or, you could cut access holes in your bumper and mount them to the sides of the frame. I'm considering doing this myself.
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
  6. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I have mine mounted in the front on each frame rail also. It did not come with the truck. I bought the hooks from JCW for $10 for the pair. Its a 10K lb test. You'll need a 1/2" drill bit and drill two holes on each frame to mount the hooks. Very easy. Here is a pic. This is the best pic I could find.
    Boss
  7. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    Mine are factory, also mounted to the frame rails. I have a reciever in the back.
    Blazin' in Flagstaff
  8. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I used to just feed the strap into the reciever holder and fasten it in place by running the pin through the loop. No probs so far....
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
