where is the h2o going
Discussion in 'The Garage' started by samiam, Jan 1, 2005.
  1. samiam
    samiam Registered Member
    May 17, 2003
    Earlier I posted about a 73 that wouldn't idle. Well after changing almost every bolt on including plugs,wires, vacum lines, EGR, cap and rotor and modual, vacum modual to the tranny,fuel pump and filter, adjusting the timeing and carb it still is not right. Thanks for all the suggestions and I have tried almost all of the fixes. One thing that I failed to mention was that the over-flow bottle from the radiator has to be refilled daily. The motor never runs hot but at times it will spike to 220 then drop to 180 almost immediatly. Could this be a head gasget issue??
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    Forest, VA
    Sounds like a head gasket to me. Check your oil and see if it is milky. HAd this happen to my Malibu then I learned never to do a head gasket on a FI Chevy Malibu the hard way.
