Where is the reverse switch mounted. Inside steering column, under dash?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sax Art, Jan 29, 2001.
  1. Sax Art
    Sax Art Registered Member
    Dec 12, 2000
    49
    Western, Wisconsin
    I've got no back up lights. I looked at the tranny and it looks like everything is hooked up correctly, so my next step would be to look for the switch inside the vehicle. So where did they hide it?
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Now its been a while since i spliced in the aux back up lights, but if i remember correctly, the back up switch is on top of the column, right above the brake pedal, i think mine has big purple wires on it, i think thats also to neutral switch, thats if i remember correctly, which is difficult after yesterdays festivities.
    RaisedK5
    "Friends don't let friends drive Fords"
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Give that man a cookie, 'cause he's right. What year is the truck cause some are a little different from others?
    June 2001 - The Texas Sawz All masacre begins. Be afraid rust, be very afraid. [​IMG]
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    It's in the same switch housing as the neutral switch mountee on top of the steering column. The wires should be light green and dark green or dark blue. The switch should be closed when you're in reverse. Now, fill out your profile so we can better serve you......kinda like K-mart huh?[​IMG]
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
  5. Michael
    1,576
    Sherman, Texas
    It's in the same switch housing as the neutral switch mounted on top of the steering column. The wires should be light green and dark green or dark blue. The switch should be closed when you're in reverse. Now, fill out your profile so we can better serve you......kinda like K-mart huh?[​IMG]
    Michael[​IMG]
  6. TPI86
    TPI86 1/2 ton status
    Mar 25, 2000
    121
    Gilbert, Arizona
    You guys are correct, I have a 1986 K5 mine is also located on top of steering column just above break pedal. I did'nt have back up break lights either. I found that mine is adjustable, I grabbed it with my thumb and forefiner and moved it until my back up lights came on. Of course you have to have ignition on (vehicle not running) and gear selector in reverse for lights to come on to check............Eric TPI86
