Where is the tan wire????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SUBFAN, Mar 16, 2004.
  1. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    '90 Burb, 350 TBI....
    I would like to check the timing, but which wire is the one you disconnect? I see red and white, but no tan. One of the white wires coming off the coil is not connected to anything, is this normal, or WTF?
    On another note, who was the retarded engineer that stuffed all that stuff around the dist. hold down bolt? Was he the same guy that hid the oil pressure sender on that funky adapter under the dist???? Talk about making an easy job more difficult - man I miss the '77 /forums/images/graemlins/ignore.gif
  2. Grim-Reaper
    7,385
    Atlanta
    Tan wire for timing is on the harness just before the bulkead connector under the brake booster.
    The loose wore at the coil is the Tach lead.
    Yeah the Map sensor is a littl in the way. Not as bad on my 454 and the smaller diameter distributor helps make it accessible.
  3. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    The tan wire is located inside that big black wire loom holder that is behind the brake booster. Unclip it and all the wires are inside there. You will find the tan wire with a male/female connector. Just disconnect it and you will be able to check your timing correctly.
  4. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Its outta the 4 pin connector on your distributor. Its tan w/ black stripe. Buy a disconnectable crimp on connectors so that you can easly disconnect later.
  5. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Darned engineers! I finally bought one of those spiffy wrenches to get to the hold down bolt. If you remove the MAP sensor from its bracket it is easier.
    Like Grim said, the wire is right below the brake booster and already has a quick-disconnect connector on it.
  6. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Thanks for all the fast replies....That wire should be easy to find now, especially since all the sleeving just crumbles to the touch....
    Gotta pull the cap and rotor again, it is having a clearance issue you can hear /forums/images/graemlins/doah.gif
    Looking down the dist. hole, this motor has all, if not most of the 310,000 miles on it, what a freakin' black hole mess....
    Thanx guys /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
