where is the wire from the cigarette lighter supposed to go?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Apr 7, 2002.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    The wire running to my cigarette lighter just ends. Is it suppsed to go to the fuse block or what?
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    It's an orange wire that should go to the fuse box. It should be marked as "Bat Fused" or something similar.
  3. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    One wire from either prong on lighter (doesn't matter which one) to power source at fuse box, either ignition hot or constant hot (I use ignition hot). There should be some open prongs on the fuse box to plug into. Make sure the other wire from the cig lighter is to ground. Use a test light to find an ignition hot prong in the fuse box.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    It does matter what prong you use for "HOT" on the back of the lighter. One is for the "GROUND" and one for "HOT". I had to try to hook mine back up with the lighter still attached to the dash and missed and got the wrong prong and kept blowing fues. I thought I had the correct prong until I finally removed the damn lighter from the dash. DOH, wrong prong.
  5. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    The rule for cig lighter housings is:
    Center = +12VDC ("hot"), outer = ground or no connection.
    The outer prong on the housing grounds to the ashtray/door assembly, which is chassis ground in itself. Connecting the "hot" wire to this prong will blow fuses, as previously mentioned.
  6. Skigirl
    Apr 2, 2001
    2,563
    Don't think it mattered on the aftermarket one I bought, if I remember the package directions correctly. Of course, I do have CRS, so maybe I don't remember correctly, or at all /forums/images/icons/crazy.gif. Good to know the rules however.
