Where or what bracket for york ac pump, to fit chevy? **** its in!!!**
Discussion in 'The Garage' started by uglychevyZZ4, Aug 24, 2002.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    where can i get a bracket to bolt a york ac compressor to my sbc? or if there isnt one, who has fabbing papers? /forums/images/icons/wink.gif
  2. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Re: Where or what bracket for york ac pump, to fit chevy ?
    working on drawing up a mount for mine.... you could probably benifit from part of it if you wanted to build your entire bracket instead of having to buy it, I'll let you know when I get it going
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    there isnt a junkyard option?
  4. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I dont know, thats what im trying to figure out???? all I know is they mostly come off foriegn cars, sooooo???? /forums/images/icons/confused.gif
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    that doesnt compute with me, they are american pumps...
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You can get original brackets for a small and big block and a Yorks. They are usually found on cube vans of some kind that have had AC converted on to them. I have seen several small block brackets and have a Big Block bracket now. They come with an idler pulley deal that bolts to the side of the Yorks. The brackets have been fixed. Very slick deal.
  7. MUDNUTT
    MUDNUTT 1/2 ton status
    Aug 1, 2001
    339
    Mn
    they also came on 70's and 80's fords and chryslers.
    deck
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    They may be american pumps but chevy never used them from the factory. People have talked about seeing them on some chevy vans but to my knowledge those were aftermarket installed. They were common on fords, AMC's, volvo, some chrysler's
  9. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    thats what i thought too. so where do i find one of these brackets?
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I bought a bracket kit from kilby enterprises but it is for a serpentine setup. you might try them but unless you have a serp setup i think you will be home brewing something.
  11. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Rob, do you have the capacity to make a bracket from plans? is your alternator on the pass or drivers side, I"m designing a bracket that's pretty solid and simple for the pass side. If it works I can probably make ya one, for a small fee
  12. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Might try Arizona Mobile Air Inc. 3601 West Clarendon Ave. Phoenix, Arizona 85019 (800) 648-4475 or (602) 233-0090 (www.ackits.com). I bought a mounting kit for my 427 to mount the Sandon 508 compressor. They also have kits for small blocks. The mounts I bought could be readily adapted to fit most any compressor. Best $80 I spent.
  13. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    well after only 2 hours of tinkering, i have a usable braket, isnt PRIMO ( only 2 hours total ) but is fine for a while /forums/images/icons/laugh.gif but id like to see that one of yours.. pic?
  14. tackettb
    tackettb Registered Member
    Jul 18, 2002
    49
    Tacoma, Wa
    I have a pic of one I snagged, that came off of a suburban. I didn't remove it and I have a 6.5 so I'm not real sure how it mounts. bracket [image]http://home.attbi.com/~tackettb/bracket.jpg [/image]
  15. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    semi trucks, mainly internationals had them. the brackets from a 79 transtar international with a cummins engine can be made to work. Kenworth had them too. an 89 T-600 with a Cat engine can be made to work to and it is very adjustable.
    John
  16. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    i've got an old 74 Mustang II in the back that has a york A/C compressor on it. i was thinking of trying to use the brackets from that on my truck. maybe just a little modifying will do.
  17. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    [/ QUOTE ] ya, thats what im using, i just slightly modified it to work.
