Where the bleep is my oil pressure sending unit?
Discussion in 'The Garage' started by longbedder, Apr 20, 2007.
  1. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    1994 TBI 454.
    It's not above the oil filter.
    It's not at the rear of the lifter valley.
    The oil pressure guage works...so where might my sending unit be?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    They usually put a little elbow adapter for it, and the sending unit should be under the distributor, where you wont be able to see it. Other than that and the oil filter, I dont know.
  3. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,615
    602
    Hooper, Utah 84315
    Have to agree with never, I have never seen them any other place then what he said.
  4. dyeager535
    26,979
    What do you expect it to look like? The pressure sender and switch were combined by '94, and is a simple black plastic cylindrical piece with a 3 wire connector.
  5. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    Well, I'm not sure what I expected it to look like exactly, but I did expect a device with a 1/4" NPT fitting screwed into the block somewhere with wire(s) coming out the other end.
  6. dyeager535
    26,979
    They didn't run them off the front of the block did they? I know on some of the SBC's there is a tapped hole that is plugged, but to my knowledge was never used for anything. Wonder if the later 454's had something similar?
    Not much experience with BBC's, no idea where else a pressure tap would be.
