Where to aquire these 1st gen parts.
Discussion in 'The Garage' started by jerry303, Dec 19, 2003.
  1. jerry303
    jerry303 Registered Member
    Apr 28, 2003
    79
    Littleton, Colorado
    I almost have all of the parts required to get my 72 Jimmy on the road, the only two things that I need are supports for a 4-core radiator, and I bought the engine half of the wiring harness but there appears to be another side on the plugin on the firewall, thus another harness that I need. Does anyone know where I can locate said parts?
    Thanks in advance,
    Jerry
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I got the upper and lower brackets for the 4 core radiator from LMC. You'll have to grind a couple grooves in the lower radiator support so the lower brackets will fit. You'll see what i'm talking about when you try to install it.
    The other half of the wiring harness? I'd say you could probably find that at a junkyard?
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    are you talkin about the under the dash part?? there are 3 main harnessses. engine bay , tail lights and under the dash. i think i might have one from a 72 k20. ill check it out if this the one you need.
    69k5
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have your supports cvor 4 core 67-72 style and upper cushions too
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have your supports for 4 core 67-72 style and upper cushions too
