Where to buy 14bolt yoke?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Russell Keys, Dec 27, 2001.
  1. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    I need a replacement yoke for a 14 bolt ff. Are there different ones? I believe it's off a 78 3/4 ton. And how much of a pain in the ass is it gonna be to get off? Thanks-Rusell
  2. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Had to put one on when installing my 14BFF in my sub. Ordered a new one from http://www.ring-pinion.com and think it was around $75. (I miss my memory!)
    Wasn't tooo bad, but takes a LARGE socket. I was able to borrow one from local tranny shop.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, expect to spend around that $75 for a new one. To remove it, you need a press to press the pinion off the yoke. OR, use a puller tool to get it off if the pinion carrier support is still mounted to the rearend.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  4. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    I HAVE THE 14 BOLT STOCK 1350 JOINT ONE USED BUT GOOD CONDITION FOR 45$ AND ALSO AN UPGRADE 1410 WITH U BOLTS NOT STRAPS- 89.00 Jess
    Owner of High Angle Driveline http://highangledriveline.com
  5. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Hey Russ.. how's the 76 Blazer coming along?
    Haven't heard from you in awhile...
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  6. Russell Keys
    Mar 16, 2000
    253
    Huntsville, TX
    sounds like I might be interested in that. I don't need a u-joint though. I'm still running the small d-shaft and have to use a conversion joint. Where are you located and what would shipping be to 77340 ? Oh, is there a spec spline count that I need to know? Thanks-Russell
  7. Russell Keys
    Mar 16, 2000
    253
    Huntsville, TX
    Hey Charles. Coming along great. Still need to do some axle swapping and brake work. Can't decide on rear disc now or later. Other than that just small stuff. You know, nickel and dime you to death stuff. Hopefully this Spring I'll be able to get some windshield time in. -Russell
  8. drivelineman
    Aug 23, 2000
    707
    shipping would be cheap no matter where i am- but its california so i'd say about 12$ or so reg ups- i'd just make sure its a full floater diff out back and were done-Jess 530-877-2875
  9. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Send an email to grinkids@juno.com. I have ordered some D44 odds and ends from them off of ebay and they have the goods. Just tell them you remember them having some 14ff yokes on ebay (2-3 weeks ago) and wonder if they have any extras laying around. Right now that have 8-9 D44 yokes up on ebay ( I realize that wont do you any good ) but you can say you seen them there. Its cheap too, I bought an open carrier for my 4.88's for $20. I think the yokes went for around 10-15 bucks...
