where to buy a 502 rebuild kit?
Discussion in 'The Garage' started by shockline, Jun 9, 2006.
  1. shockline
    shockline Registered Member
    May 10, 2006
    51
    Powhatan Virginia
    I have a Gen VI 502 and I want a rebuild kit. My local auto parts store had no listing for such a thing.
    If you know where to get one please list it here, thanks.
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
  3. shockline
    May 10, 2006
    51
    Powhatan Virginia
    thanks
  4. shockline
    May 10, 2006
    51
    Powhatan Virginia
    i found lots of kits but no 502's.
  5. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
  6. bayou blazer
    bayou blazer 1/2 ton status
    Jul 16, 2004
    176
    la
    Is it standard bore? I am just wrapping up my rebuild of my standard bore 502. A buddy of mine was doing most of the shopping for me but I know that the rings were expensive and the gasket set actually was for a marine application. The stuff is not as common as 454's Let me know if you need specific details to find rebuild parts.
  7. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    You need to call Summit. Not everything they have is listed online or in the catalog.
  8. redneck396
    redneck396 Registered Member
    May 17, 2006
    10
    Riverton, WY
    Have you tried GM Performance Parts?
  9. shockline
    May 10, 2006
    51
    Powhatan Virginia
    Once again thanks for the advice and help. I would like to get some more information from bayou blazer such as motor mounts, and headers.
    Mine is still a standard bore 502 and it was a marine motor to begin with. My first problem when shopping is they ask me what is came out of, i never saw it in anything. The fuel injection system is missing so i need a intake and carb set up, i have a dual quad with 12 inch risers but i think that is not my best choice for low end torque. The cam is 450 hp with 550 torque, is this a good choice? I had considered reusing the rings since the motor only had 100 hours on it when it was tore down. There are not even marks on the cylinder walls; however i am still leary of reusing them.
    Basically i need gaskets, bearings, exhaust, intake, distributor, and brackets for mounting the alternator and air conditioning (which i really need/want to keep). I have rectangular port heads that I would like to put roller rockers on to help with the roller cam. Right now i got about $1000 in part money to work with.
  10. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I have tested this several times. They have lots of parts they don't list.
    I think some of the GM cab&chasis trucks had 502's in them. I have seen a couple of tow trucks with that engine.
    What was the reason you tore it down?
  11. shockline
    May 10, 2006
    51
    Powhatan Virginia
    I did not tear it down, i got it that way. The engine was in good running condition at the time or so i am told.
