Where to buy a new or rebuilt electric rear window motor
Discussion in 'The Garage' started by Maltesejeeper, Dec 17, 2004.
  1. Maltesejeeper
    Maltesejeeper Newbie
    Dec 17, 2004
    3
    Worland, Wyoming
    I am looking for a supplier for a new or rebuilt electric window motor for my 86 blazer. If I can't find one I might consider converting it to a manual handle.
  2. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    I bought mine from hi lo orielly. Works good too. Good luck with whatever you find.
    Remington
  3. bowtiewrench
    bowtiewrench Registered Member
    Oct 19, 2004
    24
    Woburn, Mass
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Try the dealer. That's where i got mine a few years back.
  5. 84yellow
    84yellow Registered Member
    Oct 9, 2003
    9
    Elma, Washington
    LMC Truck.. have anyhting you need for a stock replacement
  6. Grim-Reaper
    7,385
    Atlanta
    You tried how hard to find this?
    www.autozone.com $53.99 plus $30 core
    about same price at Advance, NAPA, MAIN or any of the chain stores. Common part, easy to find. Its listed under electrical as a "window regulator motor, rear" on most of those web sites.
  7. Maltesejeeper
    Dec 17, 2004
    3
    Worland, Wyoming
    I first went to NAPA, they only list a motor for Suburbans. Next I tried the local GM dealership; motors have been discontinued. LMC trucks no longer carries the window motor(new catalog and called to confirm), Autozone does not list any thing under window regulator on line(searched all of their data base by part name and came up with zip) Advanced Auto has one made by CARDONE for 85.99 and 20.00 core. Soooooo, I did look pretty hard.
  8. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Before you condemn the motor make sure the drive cable is not siezed up. I thought the motor was gone on mine, but it turned out that the drive cable from the motor to the regulator was bad. $25.00 at the local GM dealer.
  9. Maltesejeeper
    Dec 17, 2004
    3
    Worland, Wyoming
    I have already cleaned and lubricated all of the regulator moving parts includind the drive cable and pinion gear. I also disassembled the motor and cleaned the armature. Motor draws too many amps and is worse when cold. I also cleaned all the terminals on the supply wires. Motor is bad.
  10. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    wouldnt one for a suburban work?
  11. K5HIGH
    K5HIGH 1/2 ton status
    Dec 8, 2004
    102
    harrison twp. mi.
    just replaced mine in the 88 got it from murrays, $80. plus $20 core autozone also had one. not too much luck with dealer they said it had to be orderd 189.00:eek1:
