Where to buy an electric motor.
Discussion in 'Rocky Mountain Region' started by BadDog, Jun 27, 2004.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Well, I finally killed my HF band saw last night. One of the only really weak parts of the saw is the motor, and like most ChiCom electric motor, the HP rating is VERY ambitious and the quality is very poor. Still, it's been beat to death, having worn out and/or broken around 20 blades so far. And to be fair, it was my fault. I had been cutting some fairly large stuff for a steel rack and shelf system and ran out of water. I started the last cut of the day and went to refill the water bottle, got side tracked for about 5 minutes, and went back out to find out that the smoke had been let out of the motor. It had apparently jambed right after I went in and the motor housing is cooked, the labels started peeling off, tripped the 20A breaker, and it looked like a smoke signal going up.
    So where can I get a small motor for this thing? This is the saw and I'll get the shaft diameter later. Supposedly "1hp" but in a real american made and rated motor, 3/4 would probably be an improvement. I've seen no limitations due to power or quality, so I'm not really interested in buying a "good" industrial quality motor. And yeah, you guys know I'm cheap...
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Until you can get/find a good motor, find an old dryer motor and put on it. I've got one on my bandsaw and its been there for close to 5 yrs now without any troubles, plus it was actually better than the factory JET motor /forums/images/graemlins/thumb.gif
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    My dad has had these motors on his bench grinder, bandsaw and table saw for the past 20 yrs. /forums/images/graemlins/thumb.gif
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Cool,thanks for the idea... Now to find an old drier...
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    PM me, I have an old one or two I can scrounge up from work, actually have a warranteed one some idiot installed , tried to return when it wasn't the problem , I took it back to avoid a scene , and can't sell new now . I actually also have one I need to give to Bob next time I see him too. /forums/images/graemlins/thumb.gif
    BTW use an old washer motor instead , they are heavier than dryers /forums/images/graemlins/waytogo.gif
  6. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Try Grainger. I am sure you have one near you. They will have it. You usually need an account (which is easy to setup, or PM me and I will give you an account number to use). They have a huge selection of motors and will have one for you. /forums/images/graemlins/thumb.gif
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Grainger is in Tempe AZ on wilson st, near broadway and roosevelt /forums/images/graemlins/k5.gif
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    There is also a Grainger in phoenix on 30st street and washington. Just about a 1/2 mile west of 4wheelers supply.
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Grainger is also on 33 ave and Virginia. /forums/images/graemlins/rotfl.gif Let play more name the local grainers. /forums/images/graemlins/histerical.gif
