Where to buy an output shaft?
Discussion in 'The Garage' started by neverendingproject, Sep 20, 2006.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I need a 4x4 output shaft for my 2wd 4l80e. Anyone know where to get one?
  2. dyeager535
    26,978
    Good transmission place or probably even GM. Last I asked around they were only $75!
  3. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Any idea how much a reputable trans shop would charge to swap out outputs?
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    if you are going to swap in a shaft. get the one for a 1 ton van . its a full spline slip yoke on the tail shaft. then if later you need to cut some off to fit like a swaped in 205 or 203 range box on. you wont need to swap the shaft again.
  5. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Please explain.... im confused. :confused:
  6. sweetk30
    Nov 1, 2004
    25,537
    536
    most of the shafts are splined just so far. this one is full splined all the way to the back of the case. so all you need to do is cut off what you dont need.
  7. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    So why couldn't I just get a 4X4 shaft and be done with it?
  8. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    This is the full splined 4L80 shaft with the part # shown from GM Direct for around a hundred.With this shaft you could hook up just about any type transfer and cut off the extra.The best part about it having the extra spline is being able to use a short input 205.
  9. sweetk30
    Nov 1, 2004
    25,537
    536
    yes you can.
    but we are just trying to save you money in the long run. as most of us hear have done and do. we change to better parts. so this was just a futer plainning ahead money and time saving option for you.
  10. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Im sorry, Im still confused. Its sounding like you think that im rebuilding the trans and going 4wd sometime in the future, but Ive got a rebuilt 2wd and I need it 4wd. If the above statements still apply, I still dont get why a van shaft is going to save me time and money in the future, but bear with me.
    I found this, can anyone cross-check as this being a 4wd output shaft for a 93 4l80e? p/n 8661598
