Where to buy Battery Bolt down
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Boss, Sep 17, 2001.
  1. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Besides the dealer, where can I find the bolt and metal piece that bolts the battery down?(or if anyone has one, If I can buy it yah). I'm currently working on a Dual Battery setup. I have a driver side Battery tray (thanks CaliK5), but don't have the bolt down piece for it. Went to local parts store and no go. (nothing new). Anyhow, thanks.
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i myself don't like the factory hold downs, IMO they don't hold a battery worth a %$@# especialy when doing some hard core bounce'n down a trail, not metion they dig into the bottom of the batt. i use a peice of flat steel and just bend a 90 deg on one side abd bolt it to the rad. support and on the other end drill a hole and run a piece of all tread down to the bottom of the batt. tray where the stock hold down bolts to and just bolt her up. and all these can be got from your local home depot. or you can go to LMC.com or yearone.com or classicindustreis. hope this helps
  3. Boss
    2,550
    Maryland
    Beater,
    Yeah, I was kinda thinking the same. I know the older hold downs are crap. My 75' K5 hold down was crappy. But my 89' is nice. It holds the bad down nice and firm. I was thinking about fabbing my own, b/c the bottom of Optima batteries doesn't look like it sticks out far enough for the hold down to grab it tight. Not sure if that's the case , b/c haven't tried it yet, but that's what I'm thinking. Thanks for the advice.
  4. beater74
    May 29, 2001
    1,749
    atlanta
    your right on the optima. i to run a optima and thats the main reason i got rid of the stock hold down, i just didn't hold the optima very well. there's nothing worse than having a hundred dollar batt bangin around the engine compartment.
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I picked mine up at Checker Auto - it's a plastic coated steel job, made by Exide. It cost something like $6.00, and has survived all sorts of bouncing around, washboard, jumps, etc. without ever letting loose.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  6. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You can use the stock hold down with an optima. You just have to grind it a little to make it fit. My factory hold down held my battery in when I rolled it 6 times. It you can find a factory one I would use it, if not get a universal kit from a parts store like car quest.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
