Where to buy drive sleeves for a 205?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, May 30, 2002.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Where can I get one? This is the 27 spline coupler that goes between the tranny and the case. I'm not sure I NEED one but would like to compare the one I have to a new one to check for wear. Also which way does it go on? The internal flat area forward or rearward facing?
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Junk yard or dealer, I don't think auto parts stores can get them. Maybe a tranny shop might be able to get them (but they probably get them from the dealer too). I believe IIRC that the side with the flat goes toward the tranny as the flat covers the speedometer drive gear area (not used on 4wd vehicles), but somebody may be able to give you a definite answer.
  3. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Thanks again Leadfoot. Hopefully someone will know for sure which way it goes on. Once I get it apart it might be obvious. I have a tranny shop looking into the sleeve now. The drag is I'll have to buy it to compare the two.
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I bought both of mine from the dealer. They were the 10 spline for the 4sp however. Still have one new in the box yet.
  5. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    There is one on ebay right now... I believe it was around $50-60... don't remember right off... just do a search for NP205 (including titles and descriptions).
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    heres one: <a target="_blank" href=http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&amp;item=1832841871&amp;r=0&amp;t=0>http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&amp;item=1832841871&amp;r=0&amp;t=0</a>
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
