Where to buy TH350/NP205 coupler
Discussion in 'The Garage' started by CyberSniper, Nov 6, 2004.
  1. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Where can I get a TH350/NP205 coupler?
    I lost mine on the side of the road. I have the adapter, the transmission, the transfer case, but no coupler.
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    well as luck would have it, I did find one by the side of the road the other day /forums/images/graemlins/deal.gif /forums/images/graemlins/rotfl.gif
    seriously, check ebay...just search "NP205", there always seem to be 1-2 on there at a given time.
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    there are a couple of styles IIRC.
    my extra one got sold on ebay a while back in the day of slush boxes. some go for decent $. crazy.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I bought a brand new one from a local shop near St. Louis, it cost me around 75 bucks. He had to order it from Minnesota.
    GDS 4 X 4 & Drivetrain Service
    24 Schiber Court, Maryville, IL 62062
    (618) 345-4294
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I bought a drivesleeve from 4x Heaven for $50...
    800-800-1679 (NY)
  6. MoonMan
    MoonMan Registered Member
    Mar 12, 2003
    56
    Tyrone, Pa
    A year ago I got a coupler for a SM456/NP205 (10 spline of course) from GM for only $35. I dont know if you could get one for the TH350 or not, but its worth a try.
  7. diesel4me
    Jul 24, 2003
    17,552
    939
    Massachussetts
    The 2 TH350 to NP205's I had didnt use a coupler like the SM465's did(they look like a pipe with splines inside)--the ones I had joined the tranny shaft and the input shaft of the transfer case by using a ball bearing with splines machined into the inner race,the bearing was mounted in the adaptor with 2 snap rings,and had rubber seals on the bearing to keep the ATF and 90W gear oil separated. I have seen other ones that the tranny shaft slid directly into the input of the transfer case too.I wonder why GM used so many different cases,adapters,and tranny designs?? /forums/images/graemlins/confused.gif--their engineers must be easily bored I guess---. /forums/images/graemlins/crazy.gif /forums/images/graemlins/screwy.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You just failed to pull the coupler from the transfer case. AFAIK, all TH350/NP 205 combos use a drive sleeve.
    TH 400/NP 205 does not.
  9. diesel4me
    Jul 24, 2003
    17,552
    939
    Massachussetts
    Thats very possible--I pulled the transfer cases out to store them away until I sold them,never took the adapter off either one. /forums/images/graemlins/crazy.gif
  10. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    i have seen a 205 adapter with and without bearings as diesel4me is saying. its been a couple of years when i cracked one in my rig. it was just a drive sleeve with a couple of seals. the one i replaced it with (350/205 combo) had a pair of bearings in the adapter.
