where to buy u bolts
Discussion in 'The Garage' started by RGV72BLAZER, Feb 4, 2007.
  1. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    any online sources for u bolts for a D70 HD. the local guy says he needs a old u bolt to go off, which i don't have, and at $40 for the pair, i don't want to risk getting the wrong ones built. any help would be appreciated. i'm planning on swapping in the 70 this coming weekend, so i have this week to find some.
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i know ord sells them, when i was in a pinch i hit the junkyard for them
  3. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    do you have the u bolt plate??? you can use that for an accurate measurement, just bring it with ya
  4. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    top plate = tube dia for round bend size. then bottom of tube to top of spring pack with all added up. tube dia+spring pack thickness+and perch hight+top plate and allow for washers and nuts thickness.
    bottom plate = spring width for square bend+thickness of spring pack+tube tia+ hight of perch +and bottom plate with room for nuts and washers.
    so if you have a 3.35" tube its a 3.35 round bend for top plate style.
    and if 2.5 wide spring its a 2.5 square bend . then if you have the axle all together and ready for ubolts and you have 11" of rod length needed it will be 11"legs. just a basic idea to measure them.
  5. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
  6. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    just remember that u bolt are mesure from the inside for whit and the inside of the arc for lenght
    dont forget to add extra lenght for the deepnut and extra thick washer that u should use
    i work in a spring shop so i play whit u bolt aaalll day long:(
  7. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
