Where to drill hole for clutch master cxylinder in auto to manual swap?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Jun 10, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Okay, I have an entire pedal assembly now, but where do I drill the hole for the master cylinder in the firewall? There is a hole already there that is about level with the brake master cylinder and it has tehi speedo cable running through it...I was thinking that is where the pushrod for teh cluth MC goes... Any ideas...thanks in advance for any and all help...
    Chris
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    nope that aint it.
    a little lower there will be some indents that will centre your drill
    apparently the little support rods will guide you to it if you have them installed.
    i drilled it in that spot before i found the right spot.
    I have a pic or 2 if your email will accept them
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Do you have the Hydro pedals? If so the Clutch master uses the braces from the Hydro pedal assembly.
    If not, it is LOADS of fun to set them up. I did this on my firends 72 blazer. He did not have the Hydro pedals. He had the stock pedals. You need to get both left and right and up and down correct for the angle of attack for a Master clutch cylinder.
    If I recall, you use about 2" below the hinge point on the non-hydro pedals, this is where you will drill another hle for the Clutch rod.
    Then about 4" below that and perpendiculiarly level across to your firewall is ABOUT where your Master Clutch cylinder will go.
    Check it out...
