Where to drill the steering box for hydraulic assist?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sandman, Jun 3, 2002.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have found a ram and know a guy for hoses but I am not sure where to drill and tap the box. I searched and saw that some were tapped up on top and some tapped the end cap. Does anybody know where exactly to drill and tap on top of the box? Thanks.
  2. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Anybody?
  3. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    I know Titanic did this you may want to send him a PM.
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks.
  5. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
  6. WhiteWhomper
    WhiteWhomper 1/2 ton status
    Sep 23, 2000
    227
    Highlands Ranch, CO.
    It is actually pretty easy, but kinda hard to describe with words without pictures.
    Basically, the first hole goes in the necked down portion where the hoses from the power steering pump attach. The hole needs to be perpendicular to the ground and right at where the necked down portion starts to slope up to the main box section.
    The second port goes into the small rib channel that runs underneath the steering box from the front to the back. I placed this hole relatively in line with the upper hole. This hole is pretty hard to tap, because the port is not very big, so you need to drill some into the wall on the otherside a little to give added depth so the tap can thread deep enough.
    A few of things to watch out for: When tapping with an NPT tap, beware not to tap too deep, as they are a tappered tap and the fittings will need to go in too deep to seal if you run the tap in too far. (Ask me how I know). If the upper fitting goes in too far, it can interfear with the piston that moves in that chamber. And the lower hole can get blocked off if the fitting goes in too far making the system slow or unresponsive which could be very hard to diagnose.
  7. WhiteWhomper
    Sep 23, 2000
    227
    Forgot to say, that if your concerned about not drilling in the right spot, you can drill in the end cap and the top. I just don't like how the hoses splay out in different directions when hooked up like that.
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks for all the info. Me and another guy are going to give it a try in a few weeks. The pics are a big help.
