Where to find a 4BT?
Discussion in '1982-Present GM Diesel' started by ntsqd, Aug 15, 2004.
  1. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I've about concluded that a 4BT, perhaps tweaked a little - perhaps not, would work very well in my Sub. The 6BT's fit is a bit tight and I don't need quite that much power. My trouble so far has been finding one. I understand that some came already bolted to TH400's in delivery vans/trucks. If these exist one of them is what I'd like to find as I had to get the Sub's 400 rebuilt a while back. My trans guy said making it work with a diesel is mostly a matter of a diesel shift govenor and a diesel converter.
    Any pointers on finding one?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well to start:
    They were offered i\with a th400 but that case was different, just like the th400 on the AMC is different.
    You will have to find a th400 from those trucks.
    I have an SM465 from one of those trucks with mine.
    As for the 4BT, I have a source for remans and new 4bT, I will try and find the number for you, they have a place in SOcal and I have their 800 number.
    /forums/images/graemlins/dunno.gif
  3. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    So the TH400 version doesn't have an adapter? How about those with the 465 behind them, is there some sort of adapter, or do they use a unique B/H?
  4. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    let me clarify some things.
    the 4bt is a 6bt with 2 less cylinders. same water pump, injectors, and bolt patterns.
    a 4bt ,iirc, is a sae#3 bolt pattern. the motor in the frito lay trucks, whether automatic, or standard used an adapter that was approximately 2" thick. it also mounts the tranny on a 10deg rotation. i was told due to the motor height that the motor was mounted on a lean and the tranny would stand straight up.
    1) auto/manual use the SAME adapter. the manual has a mounting pivot for the clutch, that appears to be added AFTER casting. the adapter on the frito trucks IS ON A LEAN
    2) a 6bt adapter to nv4500 bellhousing, as well as flywheel,clutch etc.... works fine
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well my SM465 has a different belhousing not an adapter, I have no idea how they did the Th400, could be an adapter /forums/images/graemlins/dunno.gif
  6. mcinfantry
    Dec 2, 2003
    308
    damn, im not sure. the one i bought had adapters (sm465's)
    my buddy has 4, and two are th400's and all 5 total have adapters from sae#3 to sm465/th400... the sm465's have a pivot pin for the clutch linkage
  7. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    A manual is out since I have a recently rebuilt TH400 and have no desire to row gears in the Sub.
    Where do I go about finding the #3 to GM B/H adapter + the bits to attach a TH400 converter to the crank?
  8. mcinfantry
    Dec 2, 2003
    308
    let me ask my buddy
  9. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Jamie Avant......
    Diesel Depot
    478-552-9510
    avasalv@mylink.net
    Good guy /forums/images/graemlins/waytogo.gif I got my adapter from him....He also has complete motors....probably anything you need 10 times over.
  10. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Gracias.
