where to find a SM465 shifter
Discussion in 'The Garage' started by Jeromy Gibson, Feb 18, 2004.
  1. Jeromy Gibson
    Jeromy Gibson 1/2 ton status
    Apr 17, 2003
    127
    Amarillo Texas
    subject just about says it. My shifter is worn out and needs to be replaced. Where is the best place to find one or is there something like a bushing that could be replaced?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Does anyone make a aftermarket shifter for the SM465 ???
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    keep your eye on ebay.
    you also can attempt to weld yours. most likely it is cracked, pull the shifter and it should be very clear what has gone bad.
  4. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
    I just want to take the play out of it. it moves at least 5 inches while in gear. You can still hit the gears but I am sure it would be easier if the shifter wasn't so lose.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have one somewhere, ill check for wear if i can find it soon, you interested ?
  6. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
  7. Jeromy Gibson
    Apr 17, 2003
    127
    Amarillo Texas
    I poped it out last night and looked at it, the pins that goes through the shifter has wollowed out the holes, do I just need to put alittle weld in there. does there need to be any play or would a solid piece work fine?
  8. dyeager535
    26,976
    IIRC there are TWO failure points on the shifter. One is where there are factory welds that break, and then that pin. I would say no problem welding it all up as long as everything was in the same position as when new before starting. I'm pretty sure it's been done on here, and I didn't hear anything bad about it.
