Where to find "aircraft" style switches?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Overdrive, Aug 1, 2000.
  1. Overdrive
    Overdrive Registered Member
    Feb 28, 2000
    93
    Gilbert, Arizona
    Where to find \"aircraft\" style switches?
    I just added an aux. 12" fan in front of the radiator and also plan on adding a few more accessories that will require dash mounted switches. Does anyone know where to get good quality metal toggle switches.? I am looking for ones with the nice red safety cover on them. AutoZone and Checker have the cheap plastic ones but I was looking for something a little classier. Any sources would be helpful.
    Thanks,
    Overdrive
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Re: Where to find \"aircraft\" style switches?
    Check Summit, they have all kinds of switched. A bit pricey for me though. http://www.summitracing.com
    Boss
  3. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Summit and Jegs both have them, also you could try http://www.chiefaircraft.com or do a search for aircraft parts.
  4. CruisinK5
    CruisinK5 1/2 ton status
    Jul 8, 2000
    164
    Georgia
    Check with a local RadioShack. They have every kind of switch under the sun and they don't cost an arm and a leg.
    "Have you driven over a ford lately?"
  5. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    Painless wiring makes a board that you can run a large main wire to and then run the rest of your smaller accessories off of that.
  6. 87JIMMY
    87JIMMY Registered Member
    30
    MN
    I think I found exactly what you are looking for. Wicks Aircraft Supply, www.wicksaircraft.com , or 1-800-221-9425. Switches are $ 10-20 depending on what type, and the guards are $ 9.25 each. They also have lots of "Beefy" looking wiring stuff and fasteners. Hope this helps
    Scott 87JIMMY
