Where to find fuel tank sending unit?
Discussion in 'The Garage' started by dallassnowman, Sep 4, 2005.
  1. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    Where can I find a new fuel tank sending unit for my 1982 Blazer 6.2L Diesel (31) gallons?? I've searched every where, even gastanks.com :confused:
  2. dyeager535
    26,980
    I think a better question is why isn't an '84 sender interchangeable with the '82? The wiring would be the same, the gauges are the same, did the emissions change in '84 somehow for diesels? Is there a different strainer used?
    The GM part numbers that gastanks.com lists is still valid for some applications, but not the '84+ K5 Diesel.
    I'm not a diesel expert, but I don't see why a later sender wouldn't work. It should certainly fit the tank physically.
  3. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    I thought the same, so I e-mailed the sales dept.
  4. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    Oreilly Auto parts, at least I have a listing for them. Looks like your in texas so their should be one near you. I show a listing for a drivers side tank and a passenger side tank. #'s are FG05k and FG05l. Hope that helps
  5. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Actually I called them, they dont have it either. My tank is in the middle of the "bed" between the rear wheels.
  6. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    You can order off Autozone.com I just checked. Or you can have them order it at the store. $102.99
  7. rhuarc31
    Oct 21, 2003
    94
    Decatur, IL
    Heh, missed the blazer part. Let me get to work tomorrow, provided I dont' brain fart it of course, and check our paper catalogs, hate to say it but our computer system isn't very good and doesn't list a lot of stuff. So if you get a lazy or not very knowledgeable person on the phone they may not check that. We list the tank for that application, and it's the same manufacturer that makes our sending units, so it would seem weird not to have the sending unit as well. Oh hell, already brain farted I'm off tomorrow for the holiday, I'll try and remember to check tuesday.
  8. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
  9. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Really, cause I called them, they told me they cant get it!!
  10. BrianDamage
    May 14, 2001
    753
    Alabama
    check the website yourself :dunno:
    I put in your vehicle and it showed you could order it. www.autozone.com
    had the price wrong though it's $119.99
    SPI- part #FG12J
  11. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
  12. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Thats not for a diesel is it???
    I dont see where it says what size motor it fits!!
  13. rhuarc31
    Oct 21, 2003
    94
    Decatur, IL
    Question. Is there a difference between a the diesel and gas sending units? I show a listing for a 31 gallon tank in 82. Also from what I can see the 84 unit will work, though not one hundred percent positive.
  14. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Not sure if a gasser will work, but Ive email a couple of sending unit sales places and they all reply "We do not have a source for the year and model you need" !!!!
  15. dyeager535
    26,980
    I *suspect* the difference in diesel vs. gas senders is simply the EVAP vent line. I'm not positive of course, but all I can think of is that diesels at some point started using a vent line as well.
    Really need a person with a diesel sender to take some pics or something so we can compare.
  16. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    no picture but...
    My diesel has an extra wire on the sending unit for the "water in fuel" light sensor...I "tested" my gauge by plugging in new sender I had for a gas tank I never installed,and it worked perfectly when I moved the float up and down(I then knew my gauge worked,and traced wires,found a chafed and corroded wire under the cab--so it wasn't the sending unit!)...
    I suspect a "gas" sending unit will work the fuel gauge OK--just that you will no longer have the "water in fuel" light anymore..I'm fairly sure my diesel has more hose connections on the sender than a gas one does,but mine has dual tanks,not sure if thats why..it does have a "return" line,plus a "siphon" line so you can drain out water in the tank,in addition to to "feed" line.. :crazy: ..
  17. BrianDamage
    May 14, 2001
    753
    Alabama
    yes.
    You enter your vehicle in when you enter the website, I entered in your specs. That's what it came up with. Use the "choose vehicle" link in the top left corner to enter your truck.
  18. dyeager535
    26,980
    OK that makes a lot of sense.
    Water light and siphon fitting is on the diesel sender.
