Where To Find Gasket?
Discussion in 'The Garage' started by B_to_C, Mar 13, 2007.
  1. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    I am looking for the paper gasket that is sandwhiched between my SM465 and the adapter for the transfer case (205, figure 8 pattern).
    None of the parts stores can figure out how to look it up and always just suggest some RTV.
    So I used a bead of RTV around the entire perimiter this last weekend during a clutch job...and I now leave a little trail (of gear oil) everywhere I drive. I swear it might be as bad as a 1/2 pint a day.
    Has anyone else run into this problem? (of not finding the gasket)
    -I used RTV #2 (non-hardening) gasket maker.
    -I found this one Checker's website. http://www.partsamerica.com/productdetail.aspx?MfrCode=SKF&MfrPartNumber=13676&PartType=1340&PTSet=A
    The picture is obviously a generic one. If you have my vehicle plugged in it will come up with the description
    If the adapter is the same on both ends, then I assume the gasket would be the same as well. I have only had the tranny and adapter apart (not the adapter and transfer case) so I don't know for sure.
    If I can't find the actual gasket somwhere would my second best option be to buy a sheet of gasket material and cut out the pattern I need? Or try again with RTV, perhaps a different kind of RTV?
  2. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    I got one for my TH400/208 from the local transmission shop, as the parts houses couldn't figure it out either. I tried RTV without the gasket and got a prodigious leak.
    I note mine is just paper, so you could prolly do it by hand from, as you say, gasket material ... wouldn't go so far as to use cork, but...
    -- A
  3. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    cereal box and some rtv for a skim coat and a exacto knife. or local tranny shops.
  4. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    yeah the cereal box idea actually works fairly well. I dont know why straight rtv doesnt work, it does a great job on diff covers.
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    gm dealer is the best/only(?) place to get that gasket.
    the part number is 8672160 $6.49 each.
    i ordered 2 incase i needed to pull the adapter and couldn't wait for it to show up.
    FYI, if you order it from gmpartsdirect.com, its only about 3.50 but $10 for shipping, not worth it IMO.
  6. B_to_C
    Jan 15, 2003
    1,861
    Is it the same gasket for both sides of the adapter?
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    no, the np205 has a kickout on one side to clear a shaft or something. those come in a 5 pack. not sure of the part number, but its in the part number post in the advanced previews forum.
  8. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Don't go the right place the first time-(Dealership).. The dealer has OEM parts- the parts the vehicle was engineered & built with... If I were you I'd do like the other dude said and make a gasket out of a cereal box. Gota use a Lucky Charms box though. Those seal up the best.
  9. 454k30
    Sep 13, 2004
    1,613
    California, MD
    I found equal results with cap'n crunch.
  10. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    My cousin used to live in Ridgecrest. I have family in Apple Valley too...
  11. dyeager535
    26,979
    This has been covered a few times. That gasket sets clearance between the adapter and the lower bearing on the 465.
  12. B_to_C
    Jan 15, 2003
    1,861
    Yea I know Dorian, since I posted this thread I went back, dug a little bit, and found out I never had to post this in the first place...Oh well, but thanks to everyone who posted, esp. big83!
  13. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    no wonder mine leaks all the time, i just thought i was an idiot and didnt use enough rtv:doah::(
