Where to find GM 3 speed info?
Discussion in 'The Garage' started by sled_dog, Mar 25, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Dad is swapping the th350 in his circle car for a 3 speed or 4 speed, but we want to figure stuff out like gearing before it goes in. We have them sitting in the garage and the only website I found with transmission codes well none of them match these transmissions! Can anyone help me find info on GM 3 and 4 speed transmissions? The 4 speed is definetally not an M21 or M22.
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Did they make a 4 speed Saginaw box? Maybe that's what it is.
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Yes they did
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    The 3 speeds are somewhat a rare variety. I had a parts truck that had the 3 speed and a 205 behind it. I know for fact that some '81-'91 trucks had the 3 speed and 208's behind them. Yep, seen and drove one myself. I've got a 3 speed/205 adaptor in the garage. It don't look anything like the 465/205 adaptor at all. Very different. But both the 3 speed and 465 use the same t-case to interchange between them.
    I've got a GM service manual that says something about the 3 speed but don't have it with me right now and it does have some M-code for it. Would need to check. /forums/images/graemlins/whistling.gif
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    I found my service manual (it was buried under some magazines on my desk). It shows 2 different types of 3 speeds.
    One is a 76 mm.
    The other is a 77 mm.
    Thats all the manual shows for 3 speeds. Don't say what M-series tranny it is. /forums/images/graemlins/tongue.gif
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  7. wicked jester
    wicked jester 1/2 ton status
    Jan 8, 2004
    139
    CANADA
    Here's a link you can try. I hope it helps you out some.
  8. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i have a gear ratio chart for saginaw and muncie 3 and 4 speeds....(i used to run circle track)....there will be grooves on the input shaft of the tranny...on the splined part where the clutch normally sits....they have from none to 4 lines on the shaft....figure out the lines and ill tell ya what ratios are in each one /forums/images/graemlins/waytogo.gif
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    There is no link in your post Wicked Jester. If you scrolled to the bottom of my second one you would see gear ratios for 3 and 4 speeds. I corrected my post to say scroll down. Not too hard now is it. /forums/images/graemlins/waytogo.gif
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    didn't see any grooves but hey we just slapped the 3 speed behind the motor and slipped her in. I welded on the Crankcase evac system to the headers and we dropped the motor in. Being the young gun I was the one on my back under the car doing the motor mount bolts. Why is it I am always under mud vehicles? My K5 and this dirt track car? Should have pictures soon, hopefully taking it to the track tomorrow for a shakedown run. Just waiting on the MSD ignition from Summit and need to grab some leaded fuel.
