Where to find new spring perches?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, Jun 27, 2001.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    Where can I find new spring perches for a 14 bolt rear. I know some of you guys have fabricated your own. I am not sure I want to unless they are expensive or hard to find. Thanks
    BlazerBoy
    <A target="_blank" HREF=http://www.geocities.com/generalblueballs/>http://www.geocities.com/generalblueballs/</A>
  2. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    I got my spring perches (for a 2.75" diameter tube, approx 4.5" long, 2.5" wide spring, can modify it for a C14) from either Milodon or Moroso (forget). It's in their catalogue. You can also get them from Currie. Expect to pay roughly $15 for a pair, to me it's a good price.
    --Rob
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    The ones I got were by Moroso from Summit.They are identical in size ,shape ,and thickness to the factory ones and they were less than $20.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  4. BlazerBoy
    639
    Chicago IL.
    So the ones for 3" dia. axel tubes work fine? I just looked through the catalog and it seems like that is all they have are for 3" dia.
    BlazerBoy
  5. tlarsw
    tlarsw 1/2 ton status
    Jan 12, 2001
    270
    Cameron, NC
    I took a grinder to the stock ones and ground the welds off around them and beat them off with a 3lb sledge. It took a little bit of time tah just cutting them off with a torch, but I rewelded those back on. They are so much stronger than the after market ones I've seen.
    1986 K10 TPI350/NV4500/Gen2 Doubler/D60(ARB)/14FF(Detroit)/4.56 gears
  6. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    As long as the tube your putting it on is 3" in dia.I guess if it was a bit bigger you could grind it a little to fit.
  7. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Grinding the welds off of the ones on the axle and reusing them sounds like the best and cheapest way to go.
