where to find nylon rope winch cable???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by leadfoot067, Aug 8, 2002.
  1. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    anybody know???4wparts doesnt know,andthe other local 4x4 shops dont either,can anybody help????? i saw the stuff on a warn winch on a rig about a year ago...thanks
  2. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
  4. leadfoot067
    May 14, 2001
    1,563
    thanks found it!!!!
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I got mine from Masterpull. For all the benefits that they have, there is a drawback. The rope likes to squish into the rest of itself when using it under a heavy load. I've had three guys yanking on it before to get it unwound from the drum.
  6. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Would you buy it again or stick w/ steel?
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Wow, the folks at Master Pull really should hire someone that can actually SPELL to do their website updates. Click on their "Warning" link to see what I mean. /forums/images/icons/shocked.gif
  8. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    WOW, that was embarrassing......
    I have no idea what that product costs, but it sure undermines that companies credibility (and their ability to get my $$$) when they have so many typos in their own product info.
    If they can't even spell....would you trust their rope to save your truck....or your life? /forums/images/icons/shocked.gif
  9. Grim-Reaper
    7,385
    Atlanta
    The stuff Rockstomper sells is the same stuff but there are some differences. I don't think you can get the cool hook. And Rock stomper is cheaper and Scott at Rockstomper is Nice and doesn't make threats to competetors like Master pull did to Scott.
    When I can afford it I'll be getting it from Rockstomper.
    As for it's strenght. It's stronger that steel at the same diameter. I think 5/16 steel is rated 8,000 and the same diameter of the rope is close to 12,000. If it breaks it drops to the ground. Steel will recoil. No splinter to cut you up.
    Down side is this....It abriads easy. If you were in a situation that it got agains a rock there is a chance it would get cut and fail where the Cable would be fine. There is a sleave that you can put ofver the rope to help with this. You also should go to a Hawse style farley. The roller styles have gaps that the rope could get into and abraid it.
    I have seen it in Action. Keith has it on his truck. He pulled Yeild up slick rock with it no problem after pulling himself up it.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It certainly doesn't give a very professional image... /forums/images/icons/wink.gif
  11. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Oh yeah I would buy it again. One of the first times I used it was on a hunting trip. We had some deer on the other side of some ugly looking beaver ponds. I just unwound the whole cable and tossed the hook through the air with the rope following it. If I still had the steel I would have had to wade it across. Its also nicer to carry throu deep snow. I paid $244 for the biggest one that they had at the time.
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    Go with Rockstomper! I just got mine a couple weeks ago and Scott is GREAT to deal with!!!!!!!
    And Grim, yes you can get a big hook with a safety catch from Scott!!!
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yes you can get the cool hook from Rockstomper!! /forums/images/icons/smile.gif
  14. Emmettology 101
    May 9, 2000
    8,126
    FL
    BTW, you can sort of see my cable in this pic:
    Rockstomper usually does one guard on the winch cable but I got (2) 10 footers just to play it safe. Also, I got 3/8" cable for added strenth, but he felt 5/16" was enough..
  15. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Thanks, all the respones I've seen have said that. I am planning to get some when I need to replace my steel cable. I had not thought about the throwing aspect, another plus! Just wondering, is there anyone who has this and does not like it? With the reviews this stuff gets I wonder why the winch co's don't offer it. It would seem like an easy way to jack up the price a little.
  16. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I e-mailed Warn about it and they said that they do not recommend the rope cable because the steel cable helps to cool the drum. They said that the rope cable will not help to disipate the heat. I got it anyway and have not seen any issues.
  17. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i believe we can get it up at the waterfront at the bpat docks shane, like Doc's.... /forums/images/icons/wink.gif
  18. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    I didn't think of the cable as a heat sink. I'll bet it helps for the planetery style winches. I've got an 8274 so that wouldn't do anything for me /forums/images/icons/smile.gif
  19. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I cleaned mine today. Gave a good hard yank, zipped it all out then then hosed it off. Let it dry and then rewound all with my bare hands. I did have some trouble with it. While it was drying my 2 year old grabbed all 100 feet of it or so and took off around the house with it. Found him wrapping the tree with it.
