Where to find roof seals?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bigbadjimmy, Apr 2, 2001.
  1. Bigbadjimmy
    Bigbadjimmy Registered Member
    Mar 27, 2001
    7
    Newark, OHIO U.S.
    Hello. Just wondered where is a good place to buy replacement roof weatherstripping for the roof? I know the previous owner took it off in the summer, and it leaks. Thanks.
    Anthony
  2. 85Blazernga
    85Blazernga Registered Member
    Mar 3, 2001
    44
    Georgia
  3. timebomb1602
    timebomb1602 1/2 ton status
    Mar 30, 2001
    138
    hudsonville, MI
    order a catolog from LMC truck. They have everything you could want for a blazer[well almost].
    <A target="_blank" HREF=http://www.lmctruck.com>http://www.lmctruck.com</A>
    1991 GMC Jimmy, 350 tbi, stock for now, but not for long!!!
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Those seals aren't cheap. Before you spring for a set, take off the top and look to see if they're really damaged. A lot of times the leaks are caused by dirt, grass, etc. that gets trapped between the seal and the body when putting the top back on, creating a path for water to follow. If the seals look OK, clean them well and treat them with a silicone weatherstrip conditioner. Then wash and wax the body where the seals will contact it. Then carefully sit the top in place and bolt it down, using all the bolts. This will often fix the leaks.
