where to find spray on bedliner
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Apr 15, 2001.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    does anyone know where i can find spray on bedliner and how much does it cost. if there is a website that would be good or somewhere in or near san jose, ca. all i have found is the roll on stuff for like 99 bucks. that is no good.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I got some rattle can stuff from PepBoy's. It was dupli color brand. It takes alot to cover a surface (1 can for each of my s-10's wheel wells).
    '71 Blazer CST with alot of rust
  3. zach78k5
    May 14, 2000
    406
    was it just rubber sealer or did it have the grit that bedliner has
  4. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    how much were the pepboy's cans? I need to do my hard top.
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The dupli color stuff has no rubber grit in it like others do (no grit in dupli color roll on ether)
  6. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think it was like $5 a can. It would take at least 4 to do your hard top.
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    You can spray on the duplicolor stuff...I have seen the gallon size for $39.99 at Wal-Mart. I just bought it...am using it for my hard top....I have another gallon but an returning it to go buy some herculiner for the inside due to the dupli is just rubbery and has no grit which is what I want for the floor walls on the inside. If you use the dupli stuff make sure you scuff up the top first and clean up the surface really well otherwise it'll peel right off like crazy....
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    "What if the hokey pokey is what it's all about?"
  8. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    well rattle can......... 7.99 at ADV AUTO
    then their professional spray on, such as linex, and u can find a local vendor near you at their website
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
