Where to find U Bolts on the cheap?
Discussion in 'The Garage' started by SkysTheLimit, Nov 21, 2006.
  1. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    I need a set of U Bolts for a D70HD. Where can i find some on the cheap? Stock might be too short, I'm getting some perches from DIY4X with an extra inch of lift in them.
    I've searched (online) autozone & advance auto but can't confirm they have what I need.
    thx
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  3. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    I saw ruffstuff's site but they don't seem to handle anything in a 4" tube diameter. All their stuff is 3" max.
  4. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    go to a local spring shop and they can make them for you if not in stock for about 8-10 bucks a pop
  5. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I have always taken an example u bolt into a spring shop and have them make me some to match. My bud just bought some U bolts from Napa for his 14ff, I would imagine they would sell them for a Dana 70 also. They even gave him options for longer u bolts. I am assuming since there are different leaf packs offered in the rear.
  7. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    i asked every auto parts store in town, napa was the only one that was of any use to me. But they said it would take 1-2 weeks to get them in. I would say check your trailer shops, the one i went to had a bunch of diff. length streight rods tapped on each end, just told them what i needed and they bent it right there for $8. you also might have some luck @ the truck stop service station.
  8. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
  9. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
  10. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    Deaver Spring in Santa Ana,Kalifornia makes them. that is where I had mine made. I had a corrected set for a 14b made.
  11. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    I'm a bit dubious about the u-bolts that spring shops bend up. A 1/2" or larger diameter u-bolt should be grade 8, but I can't see how a shop can bend a grade 8 bolt without either breaking or seriously weakenong it. It would need to be bent in the normalized or annealed condition, and then heat treated to proper specs. This leads me to believe that these u-bolts are fairly soft, low-grade material... Either that, or grade 8 bolts can actually tolerate being bent into a wide radius :dunno:
  12. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    Awesome link. Thanks. They got just what I want. 4" ID U bolt, 7/8" thick, grade 8 with nuts and washers a little over 12" long. the whole kit is like 20 bucks.
    Saving that to favorites...
  13. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    Followup question,
    Will the U bolts from a 10B work on a D60? I have the passenger side covered (perch integrated with pumpkin) but the other side needs a set. Just want to make 1 order.
    thanks
