where to get 16.5x10 6 lug steel wheels
Discussion in 'The Garage' started by mr.smartass, Oct 7, 2005.
  1. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    any suggestions on where to order them from?? i'm pretty sure they make them... i just somewhere realiable to get them from for cheap, help me out here fellas
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    tyres1.com
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Weld Racing always has some up on eBay, ALWAYS. :thinking:
  4. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    i looked all over tyres1.com but no luck in steel rims... can you point me to a name brand or something??
  5. 74757685k5
    Nov 13, 2004
    258
    montana
  6. 72 SAC
    72 SAC Registered Member
    May 7, 2003
    76
    sacramento, ca
    I got white wagon wheels for 48 bones at discount tires. They were 16.5x8.75 or something like that. But they were also 8 lug. Check them out if you have one in your area.
  7. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    go look at summit. they have a large selection of steel rims.
  8. 74757685k5
    Nov 13, 2004
    258
    montana
    6lug 16.5s are going to be tough to find.good luck.
  9. PsychoticDeadGuy
    Jan 8, 2005
    753
    Part Comparison
    Remove All
    Brand
    Center Line Wheels
    Center Line Wheels
    Center Line Wheels
    Center Line Wheels
    Product Line
    Center Line Wilderness Series Kodiak Wheels
    Center Line Wilderness Series Scout Wheels
    Center Line Wilderness Series Wildcat Wheels
    Center Line Wilderness Series Blackfoot Wheels
    Part #
    CLL-6216515655
    CLL-6236515655
    CLL-6196515655
    CLL-6256515655
    Price
    $209.95
    $209.95
    $319.95
    $209.95
    + to Cart /Wish List
    Call to Order Call to Order Call to Order Call to Order
    Description
    Wheel, Series 621, 16.5 in. x 10 in., 6 x 5.5 in. Bolt Circle, 4 1/ 2 in. Backspace, Each
    Wheel, Series 623, 16.5 in. x 10 in., 6 x 5.5 in. Bolt Circle, 4 1/ 2 in. Backspace, Each
    Wheel, Series 619, 16.5 in. x 10 in., 6 x 5.5 in. Bolt Circle, 4 1/ 2 in. Backspace, Each
    Wheel, Series 625, 16.5 in. x 10 in., 6 x 5.5 in. Bolt Circle, 4 1/ 2 in. Backspace, Each
    Backspacing (in)
    4.50
    4.50
    4.50
    4.50
    Beadlock Functional
    No
    No
    No
    No
    Beadlock Included
    No
    No
    No
    No
    Center Bore Diameter (in)
    4.25
    4.25
    4.25
    4.25
    Center Bore Diameter (mm)
    Center Cap Included
    Yes
    Yes
    Yes
    Yes
    Center Material
    Forged aluminum
    Forged aluminum
    Forged aluminum
    Forged aluminum
    Conical Seat Taper
    60 degree
    60 degree
    60 degree
    60 degree
    Hub Centric
    No
    No
    No
    No
    Load Rating (lbs)
    Lug Nut Seat Style
    Conical seat
    Conical seat
    Conical seat
    Conical seat
    Lug Nut Shank Diameter (in)
    Lug Nut Shank Length (in)
    Notes
    40 in. maximum tire diameter.
    Offset (mm)
    -25
    -25
    -25
    -25
    Quantity
    Sold individually.
    Sold individually.
    Sold individually.
    Sold individually.
    Rim Diameter (in)
    16.5
    16.5
    16.5
    16.5
    Rim Material
    Forged aluminum
    Forged aluminum
    Forged aluminum
    Forged aluminum
    Rim Width (in)
    10.00
    10.00
    10.00
    10.00
    Valve Stem Finish
    Valve Stem Material
    Valve Stems Included
    No
    No
    No
    No
    Washer Outside Diameter (in)
    Wheel Construction
    1-piece
    1-piece
    1-piece
    1-piece
    Wheel Finish
    Polished
    Polished
    Polished
    Polished
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    ProComp has the steel wheels... 16.5x9.75 - 6-on-5.5" pattern.
