Where to get 205 mount bolts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan B., Jan 1, 2003.
  1. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Where can i find some replacement bolts for a 205 adapter, the two big bolts where it goes throught the crossmember and mounts to the adapter between the tranny and the 205 t-case?
    I'm sure i can find the bolts i'm looking for at osh, but how about the metal washer thing with 4 tabs? /forums/images/graemlins/confused.gif
    Anyone know of a kit with new bolts for the t-case adapter mounts?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I would think either the junkyard or the dealor for something like that.
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    The bolts are regular old 5/8 coarse thread. I dont know about the metal washer thing, they are just flat steel plates with the poly kit I got.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Dale Hardware aisle 30. I work tomorrow,and Friday 9:15 to 6 pm. /forums/images/graemlins/deal.gif
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Metal washer thing with 4 tabs is not a necessity. You can do without those and use regular flat washers in place of them.
    If you've noticed, the aftermarket poly mounts for the t-case don't have the 4-tab washer thingies. Nor do their instructions say to reuse them.
    All those 4-tab washer thingies do is prevent the bolts from backing out. Thats just something Loc-Tite can take care of instead of using the 4-tabs. /forums/images/graemlins/wink.gif
    BTW, the bolts are regular grade 8 hardware, in 5/8" and coarse thread. Somewhere around 3" to 4" long (can't remember right now). /forums/images/graemlins/wink.gif
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Look on the ground in Hollister.........that's probably where yours are!!!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Ooooops, sorry!...... check the mall parking lot. FARTKNOCKER! /forums/images/graemlins/cool.gif
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I just used grade 8's with a lockwasher and some blue loctite. My metal tab thing was toast, so I threw it away. Works great.
    Actually, one of my stock bolt was bent a little. Not sure why, but it was hard to remove it (can you say impact) and te new bolt went in much easier.
    -- Mike
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    They sure are - unless you use loctite or something else to postively lock them. The bolts *will* back out over time. Sometimes rather quickly as I found out the hard way. /forums/images/graemlins/blush.gif
    This also happends on the bellhousing crossmember on some 72-older trucks.
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Yeah, use loctite.
    On the bellhousing - I use only RED loctite because those SOBs are a paibn to get to and they LOVE to loosen.
    -- Mike
  10. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Hey Ryan, I will be picking up the parts from the TH400 soon I have to go down to SJ within a week to 10 days.
    If you can wait that long I will bring with me the bolts and the cross like washers.
    If you want I can even give you the rubber mounts, dunno how good they are though.
    /forums/images/graemlins/thumb.gif
