Where to get 6 lug axles for 8 lug semi floater?
Discussion in 'The Garage' started by COCHEV, Mar 13, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    will 88 and up units work out of 6 lug 3/4 ton, or is it an aftermarket deal? direct bolt in?
  2. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Yes the 6 lug shafts will slide right into the 8 lug housing. The bearing surface will be a little off but nothing to loose sleep over.
    James
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    There's at least three different shaft lengths for a 6-lug 14-bolt. IIRC, its the K1500/K2500 ones that fit the older 3/4-ton housing. (C2500 is shorter, G2500 is longer)
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
  5. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    thanks for the info! might be easier to find a 88 and up axle and just move the spring pirches. its just that the old 8 lug semifloaters are more common and cheeper.
    do you remember if there was enough spline on the 6 lug shafts to just have them cut down 1/2"???
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    I bought new ones for my 14S/F
    National Drivetrain has them: NDTATL32@aol.com
    So does drivetrain.com: http://www.drivetrain.com/
    I can't remember who I ordered mine from, but I got them for $90/each + shipping.
  7. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    just weld up the holes, grind them off, and then take them to a machinist to true them up and drill the 6 lug pattern. that's what my buddy did, but he's the machinist /forums/images/graemlins/thumb.gif
    -Scott
