where to get a 12-bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by joe84bb, Jun 29, 2000.
  1. joe84bb
    joe84bb Registered Member
    May 16, 2000
    45
    Florence, AL
    O.K. so maybe I do need to swap my 10 for a 12...do I need one from a K5 or will any chevy truck do? I can't recall, but I thought someone had mentioned earlier about having to make some small changes. Also, which years should I be looking for?
    I know just enough to know that I'll never know enough.
  2. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
  3. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
  4. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Pretty much any 12 bolt from 73 on up should fit. You can even use a 2wd axle. All you would need is the backing plates off of a 4wd axle. The drums on 4x4 chevy axles are thicker than the 2wd models. I got my 12 bolt off of a 70's model 2wd pickup and re-used the backing plates off of my 10 bolt when I did my swap.
    BIGJ
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    your need to tell the whole story, Most 2WD 12 bolts have 5 lug pattern, and 6 lug drums don't fit on 5 lug axles
  6. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    If you're going to look for an axle, I'd go for a 14 bolt. The 12 bolt really isn't much stronger that the 10 bolt and wouldn't be worth the swap in my opinion. I believe that the 10 and 12 bolts even use about the same size axle shafts.
  7. BIGJ
    896
    Central Arkansas
    Ok, I assumed the individual looking for a 12 bolt would want to replace the axles and gears, etc.... Next time I will GO OVER EVERYTHING WITH A FINE TOOTH COMB SO I WON'T PERTURB (upset) THE GREAT EXECUTIONER!!! MAYBE YOU SHOULD GO OVER EVERY POST IN THIS FORUM TO SEE IF ANY ONE ELSE EVER MAKES AN ASSUMPTION OR A MISTAKE (i forgot, you already have LOL!!). All I can say about 5 lug axles not fitting six lug wheels is, DUH!
    BIGJ
    BIGJ
  8. Jason73K5
    592
    Fresno, Ca
  9. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    i need a yes or no answer.....
    if i find a 2WD truck 12bolt, can i leave the diff in the hounsing and swap the axles, backing plate, and brakes and bolt it up to my k5?
    Knife.
  10. But how bad is the weight difference gonna hurt? And can't you beef up the 12 to get the 14 strength without adding all the extra weight?
  11. BIGJ
    896
    Central Arkansas
    Yes.
    BIGJ
