Where to get an extended driveshaft?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Jul 4, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    Where can I get an extended rear driveshaft for 6.5" of lift. Can I get by with an extended yoke or should I get an extended shaft. Thanks for the input.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    There are a couple of reputable places. I got my CV shaft from Tow woods and its top notch. High Angle Driveline is has a great reputation and Jesse is a member here so Id recommend using them.
  3. JMZ
    JMZ Registered Member
    Dec 4, 2001
    73
    Gonzales , Texas
    You could get one from a pickup, and have it shortened. That would be the cheap way.
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Go to Denny's Driveshafts (to the web site) and download the measuring tool.
    Then call your local driveshaft co. Ask they how much $$$.
    Call around and ask questions about esp. about balancing - what machine do they use.
    I found a shop that uses the same balanching machine (40k) that Denny's does, and I can just drive over there and get what I need.
    -- Mike
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    www.drivelinesolutions.com Definately talk to Oscar at Arizona Driveline. His forethought saved me lots of money and he was very patient in aswering my questions and good at explaining his points. I am a satisfied customer. You can find their ads in the back of Fourwheeler and Petersons 4wheel and off road.......JP too, I think.
