Where to get Body mount bolts for 1" body lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan B., Jan 21, 2003.
  1. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Where to get Body mount bolts for 1\" body lift
    Alright... All this applies to my '72 K5... A first gen...
    But i figured i'd post this in the 2nd gen tech forum also for some help.
    I've done plenty of searching...
    The original body mount bolts are Grade 5 carriage bolts except for the #2 position which is a hex head bolt.
    It seems almost impossible to find grade 5 carriage bolts in quanities of like 2 or 4 (less than 50 or 100)
    All the hardware stores have Grade 2 carriage bolts.
    I called some specialty hardware and fastener places and they can only order stuff in mass quanities.
    I thought about LMC ordering original bolts but i need them to be 1" longer for the Aluminum pucks i'm getting.
    So....
    I could get some stainless carriage bolts, which the specialty hardware place said stainless carriage bolts will have the same tensile strength as a grade 5 carriage bolt.
    I told the guy i wanted to replace the bolts with what was original which was grade 5 not stainless.
    I could replace all the bolts with hex head bolts and then even find the bolts in Grade 8 instead of Grade 5.
    So what should i do?
    Get stainless carriage bolts that some guy told me are about the same strength as grade 5.
    Or should i go with hex head bolts and find them all in grade 8?
    Seems like it would be best to go grade 8 bolts throughout, but then the bolts won't fit the same in the bed. I'll have some hex heads sticking up in the bed instead of some carriage bolts just being round above the surface.
    Who's done a 1" body lift? What did you do about the body mount bolts!?
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/ears.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Re: Where to get Body mount bolts for 1\" body lift
    Hey Ryan.
    I would go with grade 8 because with a longer bolt and the leverage sideways that the lift could contribute you need something a little stronger.
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    The bolts that came with my 1in body were all normal bolts no carriage bolts.
    Eric
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Bolts 4 U Might want to try this place.
  5. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Check with ORD mine came with the lift, Stephen should have them.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I say call ORD. If they don't have them, try McMaster-Carr. You can order from them online and they get it to you fast. The only problem that I forsee is quantity. You may have to buy as many as 20 to get what you need.
  7. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Thanks guys. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
    I started freaking out because i thought i read on the ord website that the body bushings and 1" body lift didn't come with bolts and hardware.
    So i started trying to find all the bolts i'd need.
    I just ordered the kit so it hasn't come yet for me to see if the bolt are in the kit also. /forums/images/graemlins/smirk.gif
    Good deal. /forums/images/graemlins/wink.gif
