Where to get bushings for custom upper shackle mount?
Discussion in 'The Garage' started by sled_dog, Jul 7, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Where could I get bushings that will fit in either 1 1/2 or 1 3/4" tubing, 2.5" wide and have a sleeve that can hold a 9/16" bolt?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    ORD is a good source for bushings and could probably help you with the sleeve too. Either them or Poly Performance!
    If I remember correctly, a YJ Spring bushing is the correct size for a 1.75" tube.. Not sure on the 9/16" part though.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    GM rear leaf springs go in a 1.75" .120 wall tube and use a 9/16" bolt. Jeep YJ springs go in a 1.5" .120 wall tube with a 1/2" bolt. Both use 2.5" wide springs.
  4. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    ORD just sold me these... they fit a stock gm front spring rear eye... I had to drill my shackles to the 9/16 size... I made a set of greasable bolts...I needed 1/4" shoulder on the bushing and these have like 5/16....but they shaved just fine with a cutoff tool in the lathe
    part number may be 2053??? Im not in the shop right now..sorry... steve will remember
    cam
  5. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    i have the energy suspension pn for a 1 1/2 bushing 9/16 bolt set at home as i need the same set. i talked to a energy susp. rep at a offroad show, i told him i needed a bushing set by size not aplication. he gave me his number, said to call him the following monday. he was a big help in finding what i was looking for. i can get it later today and post it if you like.
