Where to get cheap 140 amp + continious duty 12 v solenoid?
Discussion in 'The Garage' started by dawson444, Jul 26, 2004.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Like the title says. I have tried west marine, and granger, and advance auto parts with no luck. Thanks!
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    would a ford starter selenoid not work?
    what for?
  3. dremu
    Feb 27, 2000
    15,963
    452
    East of San Francisco
    I don't think the battery isolators would go that high, and they're the biggest bad mofo solenoids I can think of.
    You trying to do some crazy winch thing?
    -- A
  4. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Doing my own dual battery conversion. I would assume since my alternator puts out 140 amps, I would need a 140 amp solenoid? Correct me if I am wrong. Thanks!
  5. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    If the solenoid goes between the battery and the alternator then 140 amps would be the minimum. If it goes between the battery and the load, and the load consumes more than 140 amps, you will need a solenoid with a rating high enough for that load. A local 4x4 shop has some solenoids hanging with the warn winches, but they look like ford solenoids. I haven't asked yet what the amp rating is.
    I am going to make my own battery system also. I have 4 batteries from a semi truck. I will use 1 for the start battery and the other 3 can be connected to the start battery for big loads. I am going to get the power to activate the solenoid for the 3 batteries from the 3 batteries, so if the main battery would go dead the 3 batteries will use their own power to put themselves in the circuit, and I will be able to start the truck. I also plan on using 2 volt meters to monitor each seperately. I don't know why I want so many batteries, I don't even own a winch /forums/images/graemlins/screwy.gif
  6. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    There is no "cheap" solenoids that will handle that kind of amperage--they are going to run about 50 bucks or more for a good continuous duty one like a Cole-Hersee or similar brand.A ford one is bakelite plastic,they will melt if left on more than a few minites.I use ford ones in my winch remote control on my trucks small crane--it takes 4 of them to make power in and out work.Two of them are partially melted,the posts for the battery cables are kinda sagging on them(they must be the 2 that energize the "Lift" side of the curcuit that has all the strain)--I have them mounted in a metal box under the bed,so the whole truck wont burn up when they fail completely. Grainger has them,but not cheap--a good place to try would be a parts house for semi-trucks,they usually have or can get Cole-Hersee or similar brands.Its not hard to find a solenoid that can handle the amps,its the continuous duty part that gets expensive,most solenoids dont like being engaged for more than a few minites or they get hot. /forums/images/graemlins/crazy.gif
