Where to get door weather striping?
Discussion in 'The Garage' started by AJMBLAZER, Feb 20, 2007.
  1. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,791
    100
    Paducah, KY
    The passenger side W/S on Big Ugly is literally flat. If I run a hose over that side of the cab water just pours in. I know I need to do some work with the hinges but in the mean time I'd like to get some new weather striping in there.
    The local places seem to think they might have general stock of w/s that would work but none have anything vehicle specific. Then I saw the price in LMC and about went into shock...it's two pieces of rubber...:eek1:
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've got some in the garage that I bought from www.jcwhitney.com for about $15 per door. I haven't installed it yet, but it looks pretty stout.
  3. AJMBLAZER
    May 18, 2000
    22,791
    100
    Paducah, KY
    Lemme know how it installs.
    LMC wants like $55 a side unless I read the catalog wrong.:eek1:
  4. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    Someone posted you could get them from GM still for $25.00 each. I have not checked.
    Did you check CheyennePickup.com
    http://www.cheyennepickup.com/
  5. AJMBLAZER
    May 18, 2000
    22,791
    100
    Paducah, KY
    Hrmmm...have to call the GMC dealership up here.
  6. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    1A auto has them for $17 a door.
  7. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    I have dealt with 1A Auto and they were a good experience fast shipping and the parts I bought were great. Have to check their seal out.
  8. AJMBLAZER
    May 18, 2000
    22,791
    100
    Paducah, KY
    Got a website for 1A?
    I take it only the stuff from GM would be authentic GM parts?
  9. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Gotten the stuff from Jcwhitney several times. Always had good luck with it. Takes a few door slams to get it to break in to where the door shuts normally again but never had trouble with it.
  11. AJMBLAZER
    May 18, 2000
    22,791
    100
    Paducah, KY
    I keep seeing weatherstriping glue/goo listed. I take it I should order some of that as well?
  12. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    On the outer door I would but not the cab to door one it should slip over the lip and stay IMHO! Never seen it on one before, I will use it on tail gate and my outer seals.
  13. dyeager535
    26,975
    GM used the goo (as far as I can tell) on trucks with NO trim to hold it in place. Such as a base model truck cab.
    The sill plate, roof trim, etc., all holds the seal in place, on the bottem end trucks, none of this was used, so something has to hold it in place. It's nasty stuff, I don't like it.
  14. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    I ordered felt/rubber WS from JCWhitney, the pieces where you rest your arm when the window is down, and when I went to install them they were each over an inch too short. After haggling with JCW's HORRIBLE customer service reps, I tossed them and bought new ones from GM. The GM price wasn't nearly as bad as I expected. JCW had also messed up a previous order so I don't do business with them anymore.
  15. AJMBLAZER
    May 18, 2000
    22,791
    100
    Paducah, KY
    Anyone know the part number for 1A?
    Can't find it.
  16. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
  17. AJMBLAZER
    May 18, 2000
    22,791
    100
    Paducah, KY
    Cool. I should have thought to check the K5's. For some reason with the pickups it lists the whole door kit, the window stuff, and some other seals but not the individual door seals like that...?
    Common, you know you want to drive 6 hours to put these on my truck while I fix the alternator on my Tracker...
  18. AJMBLAZER
    May 18, 2000
    22,791
    100
    Paducah, KY
  19. AJMBLAZER
    May 18, 2000
    22,791
    100
    Paducah, KY
    Well, I called JCWhitney and they only showed the ZX811533A part for my truck so I ordered a set of those. Cheapest price I found by around $10.
    Oh yeah, the local Chevy dealer wanted $35 a side and the GMC dealer wanted $55 a side...:eek1:
  20. AJMBLAZER
    May 18, 2000
    22,791
    100
    Paducah, KY
    They arrived this week and I put them on today. cyber is right, the doors take a good slam now to shut correctly. Had to retrain the wife in "how to shut a big heavy old door 101".
    The JCWhitney door W/S worked great and fit perfect. In fact I took about a foot off of each one so their was plenty of material. I took it through a "no touch" carwash where they use high pressure spray and we got no leaks at all. Well, from the door seals at least.:doah: Make sure you use the part number I mentioned above, they fit great and look like a good quality copy of what my smushed originals must have first looked like.
