Where to get high lift jack stands?
Discussion in 'The Garage' started by CK5, Feb 6, 2006.
  1. CK5
    May 19, 1999
    21,622
    701
    CO
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    :crazy: At least they are only a discounted price of $199:crazy:
    Make some:D Built not bought:D
  3. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    u could try buying a set of small cheap ones and wled them up so there are bigger but im not sure how safe that would be
    Jason
    "keep on truckin"
  4. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    If need 4' probably be cheapest to make them. If you can get away w/ 3' Northern & Harbor Freight have them for $75. I got mine from HF.
  5. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    that for just one stand?
    i never saw a quantity.
  6. dremu
    Feb 27, 2000
    15,952
    444
    East of San Francisco
    "Sold only in pairs".
    -- A
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I have a pair of the Harbor freight 12 ton stands. 69.99
  8. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    I bet those are the three footers I was talking about.
    I measured mine and they are not as tall as I thought, only 2 1/2 feet, sorry.
  9. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    there was a guy in springfield oregon making em and selling them, my friend got a set at the portland swap meet. I'll see if she has his card. he makes em in any heigth.
  10. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    welding supply shops cary those types of stands.
  11. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I'll also vote for making them. If weight isnt an issue, make a wheel pyramid. Start with a 16.5 on bottom, put a 16 on it, put a 15 on it, put a 14 on it, and top it off with a 14 bolt drum (dually if you want some extra height). If you're really worried about safety, weld them all together. I use this setup in the yard at my shop all the time, and its perfectly steady.
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I made my own about that size for under $50 bones
  13. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    too tippy!!..
    I'd avoid using jack stands that are over 2' high..they get too tippy,and are a danger to work with..we used rims stacked as Afroman suggested at the junkyard to support vehicles we were torching the axles out of,etc..even in dirt of mud they are steady..
    I made 2 "sawhorses" out of 3" channel iron about 2' high,that can support anything I can fit them under..only bummer is they are "fixed height",not adjustible..I've seen other ones with adjustible legs made from those pipe "lolly colums" they sell that have holes in the telescoping pipes that worked well..the sawhorse style is much sturdier and safer than any jack stand..
    We used 55 gallon drums filled with water to support a 4x6 wooden beam, that held the body up when we changed cabs or tubs,and removed car bodies to fix rusted chassis with good results too..:crazy:
  14. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Here is my home made solution to getting my lifted truck in the air. I took some 6x6 boards, and cut them into 20" lengths. Then I criss-crossed them three wide, and screwed them down with nine #8 3-1/2" wood screws. The two jacks pictured are at 3-Feet.
  15. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    :haha: :haha: :haha:
