Where to get hub/rotors assy.
Discussion in 'The Garage' started by TB383, Mar 14, 2006.
  1. TB383
    TB383 Registered Member
    Feb 18, 2006
    21
    Texas
    I am building up a dana 44 from a k5 blazer and went to auto zone and oreillys and they both said that they do no carry a rotor/hub assemble anymore. I was told that i have to buy the hub and the rotor seperate because they no longer get in as a assembly. I was just wondering where yall would get this?? i need it for a dana 44 with 6 lug.,, thanks
  2. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    hey get with azblazer i know he just odered some not to long ago
  3. TB383
    Feb 18, 2006
    21
    Texas
    alrighty i sent him an email, thanks....anyone else you know of
  4. K5Glazier
    K5Glazier 1/2 ton status
    May 29, 2003
    220
    Chandler, Az.
    Napa had everthing I needed for the d44
  5. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Umm, do you not have hubs? Or are you changing from 6 to 8?
    I'd get hubs @ a junkyard and get rotors from the parts place ... they just press on with the lugs.
    Or am I missing the question entirely?
    -- A
  6. TB383
    Feb 18, 2006
    21
    Texas
    no you got it man, I am just replacing the hubs that are on it now and the rotors. I went to autozone and was looking for a assembly with the hub and rotor together, but i guess you can just buy it seperate and it will be fine, ill try napa
    thanks
  7. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    If there is nothing wrong with your hubs why do you want to replace them? I could see if you wanted to buy a hub/rotor assembly so you could have an extra pair of hubs. Then again, the hub/rotor assembly usually isn't much more money than buying a rotor by itself.
  8. dremu
    Feb 27, 2000
    15,958
    452
    Gaieee, yeah, why replace what ain't broke? AZBlazer was doing it to go to 8-lug.
    I'd press out the studs and replace the rotor only. Cheaper and easier, IMHO.
    -- A
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Where in Tx are you? I have a couple of those left over from a conversion.
  10. TB383
    Feb 18, 2006
    21
    Texas
    Lewisville area......are the ones you have 6 lug?
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    carquest has them i'm fairly sure.
  12. TB383
    Feb 18, 2006
    21
    Texas
    welll i guess i dont need to replace the hub then, i will just put new bearings in the one i got and then just buy new rotors....... thanks for the help guys
  13. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i am replacing my rotors on mine also ,
    do i have to also replace the studs ?
    is it better to find a place to press the studs out , or can i knock them out with a hammer ?
  14. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    if you knock them with a hammer becareful to not hit the threads, i use an air hammer with a pointed tip right dead center of the stud
