Where to get locking washers for bolts on external hub?
Discussion in 'The Garage' started by thedrip, Aug 13, 2005.
  1. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I have the older style external lockouts on my d44, but it seems I'm missing about half of the bolts to hold them on. I realize the bolts are easy, coarse thread 3/8" grade 8 will do the trick, but the OEM stuff had washers shaped to match the hub, with a fold up tab to keep the bolts from backing out. Does anyone still make these, or is it time to make my own?
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Loctite would be cheaper and easier than making your own washers.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Warn doesn't even put those in their hub refresh kits any more. :mad:
    I used grade 8 bolts, blue Loctite, and grade 8 lock washers on mine.
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I use studs with the self locking nuts. I run a standard washer behind the nuts, works well.
  5. thedrip
    Dec 13, 2003
    1,129
    Chattanooga, TN
    In my search for a suitable easily available solution, I found one thats a bit expensive, but certainly attractive. ARP header studs for a small block chevy, proper thread for the hub side, fine thread for the nut side, comes with a nut, and it's all rated at 170kpsi as opposed to the 150kpsi that grade 8 is. That plus locktite, and I might have my answer, or, for significantly less than $30, I could go to ace and get some grade 8 bolts and lock washers =)
