where to get long travel shocks?
Discussion in 'The Garage' started by k5-newbie, Sep 7, 2005.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    just like the title says and also, how do you actually measure what length you need?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    To measure what you need, compress the suspension on each corner to the max up travel(one at a time) and take a measurement between your shock mounts. Then do the same with the suspension at each corner at full droop.
    That will give you extended and collapsed measurements to go by. Then looks for a shock with similar measurements.
    Auto Zone has the Gab G63438's that are a 12" shock. Or Poly Performance has some good shocks.
  3. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Four Wheel Parts sells some hella long ES3000's, I think up to 18". I know they have 16's.
  4. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I got some pro comp shocks at summit racing for 35 ea. and they have about 15" of travel, IIRC..
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yep I got the 15" travel Pro comp es9000's from summit. They are like $30 each and are nitrogen charged.
  6. TLCOR
    TLCOR 1/2 ton status
    Aug 16, 2005
    333
    At ya mama's!
    Bilsteins or BBCSs - Fully Rebuildable with Custom Valving ! Talk to "Beat95YJ", "GOAT1", "Gordon", "TRD" or/and "PIG" at PBB. These guys know alot about *real* shocks. (ProCraps and all other standard twin-tube shocks are all made by the same manufacture. In Asia IIRC ? :doah:)
  7. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    when do ford shock towers come into play?
  8. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    When you're maxing out travel on stock length shocks. Ford towers are pretty adaptable so you can mount 'em to give you as much room as you need.
  9. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    My 4" BDS lift outflexed the shocks that came with the kit, and to go to longer shocks (12" travel) I had to go to Ford shock towers. With more lift, you can run a longer travel shock without needing the new shock towers. On the other hand, the towers are cheap and if you have a flexy suspension you will need them.
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Skyjacker has the Platinum series shocks and the longest ones they show are:
    #M9040E.....40" extended length and 25" collapsed length.
    #M9045E.....45" ext. and 27.5" coll.
    #M9050E.....50" ext. and 30" coll.
    Thems sum long ones!
  11. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    :yikes: :yikes: :yikes: :yikes:
  12. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    if u want nicer shocks my 2 cents are the bbcs. there powdercoated, valved for rockcrawling and are 15'' travel. they also make some that are 13'' travel. all depends on how nice u wana go
  13. TLCOR
    Aug 16, 2005
    333
    At ya mama's!
    BBSCs.
    Yep, they are currently valved for leafsprings "only", but they will soon (?) come out with a improved version, with coilspringvalving available also. Again, fully rebuildable !
  14. Emmettology 101
    May 9, 2000
    8,126
    FL
    Damn, I just priced some GAB G63438's and they are $29 now. Used to be $19. :(
  15. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
  16. TLCOR
    Aug 16, 2005
    333
    At ya mama's!
    Bilstein.
    Offcourse its the best - 255/70 Valving sounds about right, too..
  17. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    hijack-- How do you read shock valving it does not make much sense to me at all--end hijack :D
    Ira
  18. TLCOR
    Aug 16, 2005
    333
    At ya mama's!
    Its different from evey shockmanufacture, but Bilstein uses a system were the numbers are the force in Newtons at .52 meters/second - these numbers are taken from a shock dyno curve. The first number is the rebound dampening and the second is the compression dampening, the higher the number the stiffer the shock will be. But like i said before, check out the above mentioned persons @ Pirate. They know *alot*..
