Where to get steel fuel line
Discussion in 'The Garage' started by Chris Demartini, Jun 23, 2002.
  1. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Where can I get some steel fuel line from? I'm putting in my 31 gallon tank this week and I need to hook it up to my TPI fuel rails.
    Also, can I use 3/8" rubber fuel hose for the return, or does that have to be steel too? I think theres only 4 or 5 PSI going through it.
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I might be able to get you some stainless line through my cousin, at cost, of course. /forums/images/icons/cool.gif
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    If youre wanting the braided stainless, Speedway motors has premade lengths or custom cut ones.
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">How much is this braided stuff? I just found some 3/8" steel in a 25' length for $20 in summit. Pete, can I use the same flare and bending tools for stainless as regular steel?
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Napa sells it in 6-8' sections, that is ALL you need. Pre-assembled flare fittings are included, and you just need a union to hook two different sections together. The return can be 5/16", and can be rubber - that's what I used - stainless braided covering the rubber.
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Do these peices have the correct fittings for my fuel filter? I got one for an 87 K5. Are these lines universal, or vehicle specific?
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I just used the steel brake line sections that you can buy at the parts store. I figured that if it can withstand the requirements of a braking system, then it should never be taxed at all just dealing with the measly 45-50 PSI of a TPI fuel system. I used the same stuff for the return line, simply because it was easier to route. /forums/images/icons/cool.gif
  8. BurbinOR
    5,829
    Oregon
    Not sure, my TPI setup has the typical/standard IROC metric 14mm fittings.........so my local hydraulic supply store made me an adapter to go from standard flare fittings to the metric hookups to the supply lines. As far as pickup, you decide if you are going in tank pump or external, either way should be easy.
  9. outlaw612
    Feb 11, 2001
    2,342
    Stainless will be quite a bit more $$$
  10. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I have an 87 K5 tank and sending unit with a 87-91 camaro fuel pump (fit right in). The only threaded fittings I need is for the fuel filter, the rest I will connect with rubber hose.
  11. BurbinOR
    5,829
    Oregon
    *Personally*, I'd avoid rubber as much as possible. From the tank to the filter near the tank rubber, then steel line all the way to the engine bay, direct to the high pressure rubber hoses. Just my opine /forums/images/icons/shocked.gif
  12. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Thats how I was going to do it. I am mounting the fuel filter to the front gas tank crossmember and connecting it to the sender with rubber hose, then all steel to the engine bay, then connecting that to the fuel rail with rubber hose. I have some 3/8" high pressure EFI hose I "borrowed" from work /forums/images/icons/laugh.gif
