Where to get stock rear shackles?
Discussion in 'The Garage' started by backyardbuilt, Sep 26, 2002.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Did a search found nothing. I am thinking of getting new rear stock shackles. I called the dealership he could not find a listing for them. Anybody know where to get them, part #. Thanks for any help! Ryan
    P.S. If not any ideas on how to make my own??
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Just go get a set from the wrecking yard and put new bushings in them.
    Mike
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    GM sells them with the bushings and theyre pretty cheap. I think I was told something like $20 for the pair.
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I have like 3 sets laying around.
  5. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    14022597 Is the part number in my parts catalog. That may be an old number but it will get you started. I can't belive a dealer counterman cant find that part nor can ask another counter guy for a hand. Unreal. I'm off work today so I pop in here for a look, and in less than thirty seconds I'm typing the number. Either I'm that good or that counter person sucks real bad....
    Jim
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    have you looked into running ford rear shackles?? they are 1" longer then the chevy's
  7. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Thanks for the part# I will try that tomarrow. Not sure what I am gonna do I have to cut the bolts out of the ones I have to get everything apart not sure if it will end up killing the ones I have, I'm replacing the rear mounts finally they are almost gone when I do I'm building a rear shackle flip bracket and a home made zero rate plus 2" springs to replace my 6" block and match my 8" fronts. Hope it works flip=5, spring=2, zero rate=1, =8 I hope. Thanks for the responses.
  8. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    What shape are they in would shipping and price make it worth it not to get new ones.
  9. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    No I haven't, do they bolt right up with what I'm doing it may be worth checking out.
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    if you can get the ones for Gm with bushings for $20 then go that route.
