where to get tool for ball joints? *UPDATED*
Discussion in 'The Garage' started by LKJR, Sep 29, 2004.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    *UPDATED REPLY AT BOTTOM*
    late 70's dana 44, the upper ball joint has a threaded sleeve thing (camber adjustment?) one side I just used a punch and a hammer to turn it, but the other is rusted and it's not working. where do I get the tool? oreiley's didn't have it and the guys at autozone were too dumb, kept telling me to just use a pickle fork.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: where to get tool for ball joints?
    are you trying to take the knuckle off? i have never taken these out to take the knuckle off.
    anyway you can get it from snapon for like $20, there is a tool place near me that sells generic ones for $21. id get the snap on one
    snap on
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Napa carries the tool. I forget the name of it, off hand.
    It is the Ball Joint Adjusting Sleve tool or something. There were threads about it here.
    A Ball joint removal tool can be purchased at Harbo Freight Tool for Less than $40...
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I got my spanner socket from Snap-on.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The spanner socket is what you are looking for. I gave up finding one and just made one out of a deep socket.
    That is to adjust ball joint preload. I sugest you read up on it if you want your new ball joints to last.
  6. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
  7. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    Read up on ball joint pre-load here.
    Yes you can make one out of a 13/16 deep socket with a grinder in about 20 mins.
  8. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I made one out of an 11/16 (IIRC) deep socket.
  9. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    I made my own tool too--but I wont ever fool with those threaded sleeves again--be forewarned that those threads in the yoke are pretty soft,and get boogerred up fairly easy.My friend who runs an alignment shop told me he only changed those sleeves once on a customers truck,it turned into a real nightmare when the threads stripped out of the yoke--now he only changes the ball joints--my brother has had lots of 4x4's at work need ball joints,he said the same thing-"I never fool with those sleeves"--neither has had any trouble with the ball joints wearing prematurely or any customer comebacks--so I dont think I'll change them anymore if I need balljoints--unless its absolutely nessasary. /forums/images/graemlins/crazy.gif
  10. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    They are necessary to change. They are what you use to set balljoint preload. Important if you want your ball joints to last /forums/images/graemlins/deal.gif
  11. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    well got it off, ya'll were right, for some reason I just remembered that piece being screwed onto the ball joint, anyway finally got it off, I think somebody soaked that side of the axle is rust come here spray, lower ball joint was just flat rusted to the axle, after a few (closer to 50) hard wacks on that top BJ it finally broke lose, both ball joints are bad , if they weren't before they are now. so now to figure out how to get that dad gum steering arm off.... stuid rust.
  12. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    are you putting a lift in and thats why you need to get the arm off? if not, i have always changed the ball joints will the arm still on, its just too hard to get them off.
  13. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    lift is in, crossover, and highsteer.
  14. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    You need a pickle fork. Most parts stores will have them. They are pretty cheap too.
