where to get???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by leadfoot067, Feb 28, 2006.
  1. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i need the rear load sensing thing that controls the rear brake pressure on a 83 k-30....anybody know where to get one? my local parts stores dont even show a listing for it?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Last time i looked in LMC they had them.
  3. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    someone actualy wants one of them? most when thay go bad bypass them. and say brakes feel better after the bypass
  4. leadfoot067
    May 14, 2001
    1,563
    well deleting it did cross my mind....the brakes on this truck really suck...i cant make the rears lock up at all....other than with the E brake...mabye ill just bypass it/....
  5. sweetk30
    Nov 1, 2004
    25,544
    539
    this valve is a close relation to the sway bar that comes on are trucks. mine dosnt have ether of them.:wink1:
  6. leadfoot067
    May 14, 2001
    1,563
    ok so i took the damn thing off sunday....bled the brakes and WOW what a difference...then i took the valve apart and found a bunck of gooooo in there.....
  7. sweetk30
    Nov 1, 2004
    25,544
    539
    told ya you would like it off there.:waytogo: i wouldnt steer ya wrong.
  8. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    I had a guy tell me that was on my 90 burb. But I don't even know where to start looking. I know my brakes have always felt soft. even after a new booster, master and 3/4 ton axles.
  9. sweetk30
    Nov 1, 2004
    25,544
    539
    follow the rear line down the frame rail right side and just before the line goes in to hose bracket for rear axle. there will be a roundish box thingy with a set of arms on it to the axle. the more the axle moves from weight on it the more it opens up the valve if it works correctly.
    just bypass this unit and remove it and throw it out as thay just dont work great and after all these years fill full of sludge. then blead breaks and test drive.
