Where to have exhaust exit?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by surg82k5, Jul 2, 2001.
  1. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    What are you guys thoughts on having the exhaust exit infront of the rear tires. Would there be too much exhaust in the cab, noise isn't really a factor, being that right now i don't have carpet either. thanks for the thoughts
    sergio
    Check out my new website. <A target="_blank" HREF=http://www.surg82k5.rockcrawler.com>http://www.surg82k5.rockcrawler.com</A>
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    if your tub is pretty solid, you wouldn't have to worry about fumes much. Although witht he pipe in that location, it make them prime targets for rock, logs and whatnot that like to bash things...
    I have always liked when they come straight out the back and run the pipe in between the very rear spring hangers and the gastank... Thats the way mine used to be and wish they still were...
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  3. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    If I had it to do again...it would be side out...can't roll my window down unless i want to suck in fumes.
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  4. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    Mine doesn't exactly exit. The pipes just end right after the rear axle. Not much chance off damage there. And no fumes either.
    That's because I'm the devil.
  5. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    I agree with lehtola. I have mine coming out at angles on the rear corners and when I had the rear window rolled down (when I used to have a rear window) I would get a heaping helping of exhaust fumes. I also thought about puting them in front of the rear tires, but I think the noise would drive me crazy. Those flowmasters are not the quietest mufflers.
    <A target="_blank" HREF=http://www.thehungeronline.com>http://www.thehungeronline.com</A>
  6. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    Didn't look where you are from but in california it is only legal to have them come out behind the tires... Can't even have them straight out the back cause that is illegal also, since the rear window rolls down. Mine come out on each side behind the tires.
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    i agree with max crack. Mine exited between spring hangar and spring after the shackle flip. Figured they'd cause more damage if ripped off by rocks so I sawzalled them where they dump right after the hump over the rear axle. That sould eliminate fumes, trail damage, and black spots all over whatever is facing the pipes upon startup!!! [​IMG]
    Sherman, Tx
    <font color=red>Come Awn yall...Let's go to LUCHENBACH, TEXAS!!!
    </font color=red>
  8. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I have mine exiting out the sides behind the rear tires, but I still get exhaust fumes coming in thru the rear window.
    I've got a mind like a . . . a . . . what's that thing called?
    <A target="_blank" HREF=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</A>
  9. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I have a single 3 inch pipe exiting at the stock location behind the driver's side tire, and still get fumes when driving with the rear window down.
    Ratch
    <A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A>
    **K5 - What more is there to life?**<P ID="edit"><FONT SIZE=-1>Edited by newyorkin on 07/02/01 10:59 AM (server time).</FONT></P>
  10. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Mine exit at 45 degree angles right after the rear tires and i get exhaust fumes too but then again, it could be fro mthe rusted floor in the rear ????
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  11. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I have true duals exiting at 90 degree's behind the tires and sometimes I get fumes through the window, but it's only when I sit idling for a long time(ie traffic) if I'm moving along I get no fumes
    Murphy's Laws on Life :
    "The longer you wait in line, the greater the liklihood that you are standing in the wrong line." [​IMG]
  12. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Even out the sides (behind the wheels) I suck in fumes through the rear window. Even in my Burb, which has the air foil across the roof to prevent the fumes from comin in....they still come in.
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  13. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've got mine coming out right behind the rears at 90 degrees, and still get enough exhaust in the cab to kill a horse when the window is down.
    If it weren't for bad luck, I'd have no luck at all[​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  14. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    if your sucking fumes through the back, roll down the front windows and drive faster
  15. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    The only place I've found for decent rock protection is in the factory location, at a 90* angle behind the rear tires. I have a single 3" pipe on the passenger side, full length headers that Y behind the t-case, and a passenger side flow master big block muffler. Nice and quiet.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  16. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    What have you guys done who are running a shackle flip? Thanks!
    Dawson
    Raleigh, NC
    88 K5, 4" lift, 33" BFG muds
  17. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    mine exit behind the rear tires at 45's, but I'm assuming Pugs is getting fumes when his rear window is down. You should NEVER run with your rear window down because it creates a vacumn and sucks everything from the rear into the vehicle.
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  18. solowookie
    Mar 31, 2001
    3,880
    Wyoming
  19. tyler t.
    tyler t. 1/2 ton status
    Aug 7, 2000
    163
    I had mine bent so that it drops out just in front of the rear axle and points down. I was having a problem with the axle hitting the exhaust at full articulation.
    JEEP it's what's for dinner!
  20. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    What about soft tops. Does every one with a soft top have to run with the side windows up and the top sealed?
    Kent
    1989 K5
