where to hook up cb radio????
Discussion in 'The Garage' started by 90k5beast, May 12, 2004.
  1. 90k5beast
    90k5beast Registered Member
    Aug 5, 2003
    5
    hey im just installing a cb radio and i cant find the place in the fuse box to place it ive been using a test light but nothing has been working is there a known place to put it? if not where have yall put it. i have a 1990
  2. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    I tied into the radio fuse with a piggyback spade connector. I love those things, pull the fuse (blade type) hook the spade connector over the fuse; put said fuse back and presto....power. I mounted my CB on the front of the console. It's out of the way and I can hear it clearly.
    I also tied a spade connector into the AC fuse to provide 12V power to my ALDL cable.
  3. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    Tie it to a constant hot. I used my cig lighter.
  4. dyeager535
    26,982
    191
    Almost all of the single prong connectors at the top of the fuse panel are either 12V constant or 12V ignition.
    On a '90, I would bet that most of the terminals are already "occupied" for all of the power accessories (PDL/PWL, rear window, etc) but the connectors are universal on all 80's (and a bit later) GM cars, and there are "piggyback" connectors easily found in the donor cars.
    No better way to get power than the way GM did it.
