Where to Look for Crack in Frame Caused by Steering Box?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Qubit, Apr 8, 2002.
  1. Qubit
    Qubit Registered Member
    Mar 29, 2002
    21
    Redwood City, CA
    I've been lookin' over the blazer today to see what work to do on it next.
    It's fairly obvious the previous owner did some off-roading (lotsa dirt everywhere).
    I've heard that blazers (I have a K5 96 Blazer) get cracks on the frame from the steering box. Where exactly should I look to see if my frame is cracked? Do I need to remove the box to see?
  2. chaka454
    chaka454 1/2 ton status
    Nov 13, 2001
    199
    California
    No you dont need to remove the box if you have a cracked frame believe me you will see it right away, I know I did.
  3. Headbanger
    Headbanger 1/2 ton status
    Nov 29, 2001
    123
    Moreno Valley, California. U.S.A.
    First place to look is around the bolt holes. That's where most of the stress goes first.
  4. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Have someone in the truck crank the wheel back and forth to the stops (obviously do this with the truck running!). If the frame is cracked you will usually see the box move as it gets to the end of its travel one way or the other...and you might also hear a "popping" noise as it flexes. You could also do this test with the tire up against the curb, but if your frame is cracked, the first way should work...you might see some cracks around the bolt holes if you really look good...
    If you plan on wheeling it, I advise to put both the ORD Brace kit and the Weld-In Frame kit on now, especially if it isn't broken yet! I had the brace kit on for years, and then the frame cracked still, so had to repair it with the weld-in kit.
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I dunno if this is really a problem on the later blazers cos of the IFS. Thought it was only on the straight axles.
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Just one question guys - Would a 96 have the same steering box set up as on our straight axle trucks? I just noticed that he said he had a 96.........
  7. redrightthand
    redrightthand Registered Member
    Feb 28, 2002
    38
    SoCal
    Probably a typo, must have meant 86
  8. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    His profile says 86, so its a typo
  9. Qubit
    Mar 29, 2002
    21
    Redwood City, CA
    damn..bad proofreading...i did mean an '86 not a '96...
    sorry for the confusion...and thanks to all for the tips!
